There is no auto close for the frunk on a Pure. I'm surprised they left it in
The Pure doesn't have AUTO open but I believe the frunk button should close.There is no auto close for the frunk on a Pure. I'm surprised they left it in
It can't since it's not on powered struts.The Pure doesn't have AUTO open but I believe the frunk button should close.
Is it the struts pushing it up after latch release of is it motorized?
It’s just the latches.Is it the struts pushing it up after latch release of is it motorized?
Yes. The struts push it upIs it the struts pushing it up after latch release of is it motorized?
It should be on by default, but under settings, vehicle, doors?So I just got the car and the auto lock when I walk away doesn’t work. Is there a way to turn that on or fix?
That was exactly what did it. Thank youIt should be on by default, but under settings, vehicle, doors?
Absolutely! I honestly don’t see a problem here. There are 2 options to activate your original seating position when getting in the car, touch the brake or fasten your seatbelt. You’re going to fasten your seatbelt anyway, so why not do that first? The additional benefit of not touching the brake first, is that you’re not greeted with the continuous chimes until you fasten your seatbelt. Win win, especially for shorter drivers!The other option is to buckle your seat belt after closing the door. This will reset the seat to the saved configuration. No need to tap the brake.
I just did sprint mode for my son today (while getting on the freeway) and it was like we were getting pushed into the seatBe careful with Launch Mode. You might puke or pee or both!!![]()
