I'll also chime in to point at your outlet as a possible problem. 14-50 outlets, especially the $12 Leviton, are notorious for loosening connections over time. Hardwiring is much safer, but aside from that, use a $75-100 Bryant or Hubbell industrial 14-50 receptacle instead.
One way to tell if you are about to burn up the 14-50 receptacle and more: After charging your car for an hour or so, pull the plug fully out of the receptable and touch its two big prongs. They should be warm, not hot to the touch. If the plug's prongs are hot, don't charge your car there until an electrician has replaced the receptacle.
(electrical engineer with 50 years experience here)
Also see this:
