- Mar 22, 2022
- Air GT Black/Tahoe/19"
Where do you live? Are you using the lucid cable to charge? If so I’d bring the Lucid charger cable in to them and have them replace it. This only happens at home, or have you been able to replicate the problem at another level 2 charger? That’s actually bad advice to leave the door open as you could drain the 12v battery. I’d do two things: 1) find another L2 charger nearby and try and charge there while leaving the car. 2) if that works then it’s something to do with your home setup, possible the lucid cable. In that case ask service if you can bring the cable in, and your car so they can try it out.Been texting them every time this happened. So far, they have only been listening to what I tell them. No possible causes or solutions from them.
