AIR.LUCID
Great stuff. I stored this away in Notes. Thanks for the formatting.Feedback is great, but a consolidated list of improvements would be an easy place for Lucid to look for feedback.
- CarPlay
- Android Auto
- Charge scheduling
- Dashcam ability
- Sentry mode
- Camera while driving ability
- Nav + music screen active at the same time, or just mutli-use
- V2G, V2V, V2H charging capabilities
- Mix & match steering, suspension, and throttle
- Homelink auto-trigger
- Add bottom navigation and a side panel with Homelink buttons to the pilot panel Park/Camera screen
- Hardwire USB data capabilities
- Improved cabin temp hold (aka dog mode)
- Satellite radio, either integrated or as an application
- Max cabin temperature (like Tesla Cabin overheat protection where if the cabin gets above 105f, it controls it regardless as long as you have enough battery. Tesla created this due to component failures, but it’s honestly a wonderful feature)
- Make the freaking cars in the UI match my car color. The car in the UI is a silver DE, which isn’t even possible
- Navigation
- Google earth map overlay
- Slow to find destinations
- Short interruptions in cell signal confuse or lock up system
- More visualizations in Gauge Cluster
- Turn on anti-aliasing. Lines are jagged on the speedometer
- Faster car startup
- Let the music page remain in place in the lower screen once it’s dragged there
- Auto high for headlights/adaptive lighting
- Seats
- Comfort access/easy in out
- Passenger Seat Memory
- Heat/cool seats + steering wheel from app
- Regen settings and drive mode linked to profile
- Make Lock/Unlock more consistent with both Mobile Key and Key Fob
- Customization of Unlock/Lock
- Proximity lock - on/off
- Unlock - Driver door/all doors
- A way to turn off the car (Press park a second time)
- Comfort access (seat moves back for exit) This helps many drivers with exit and helps if drivers of significant height differences share the car.
- Faster Loading for profile changes
- Improved wireless charging dock
- Auto Wipers setting with variable speed
- Use a combination of key proximity and rear camera/sensors to open the trunk Ala foot trunk/tailgate opening
- Allow "work" address to be removed or changed to a different title i.e. son's house
- Trunk opening with foot motion (boot kick)
- Apple Car key
- Park system/Camera
- The cameras have a lag. The lag from reality to the screen inside the car is enough to be nauseating.
- The graphics overlays cover the portions of the image you most need to see. The car is not represented on the screen accurately to where it is in the outside world. The audio alerts are annoying vs informative and often go to full tone when you are in fact not that close to anything.
- The Park distance camera screen UI doesn’t even match up well with the rest of the UI in the car. Lower navigation panel is not there. The Autopark and Surround view links as well as the “x” and “mute” can be easily lost in the image.
- charge points need to adjust / adapt based on current consumption rate and not just when the route is first planned. (https://lucidowners.com/threads/enhancement-request-gps-must-be-dynamic-regarding-range.1065/)
- left hand display in addition to the current mileage/average mile/kWh must have a 5 mins running average mile/kWh (https://lucidowners.com/threads/enhancement-request-energy-usage-needs-a-5-min-average.1066/)
- Valet Mode/Young driver mode to limit acceleration/top speed
- Drive-in Movie Mode - Keep the climate on but have interior lights and exterior lights off when doors open
- Ability to turn off running lights
- Delay on regen braking when disengaging cruise control
- Auto-precondition when destination is set as a charging station
- Eco drive mode (disabling a motor while on highway or for less acceleration)
- Plug and charge enabled on other networks (Chargepoint and EvGo)
