The Pure can be 300 miles as long as the other models offer longer range.
As far as the AWD Pure I'm not sure it would have a shorter range with the two motors verse the RWD single motor model. EPA testing is done with a set acceleration rates having more power available will not result in shorter range (during testing). The weight of the additional motor is small compared to the weight of the car so no real penalty there. Plus front motor will allow heavier regenerative braking.
300 miles range is no where near sufficient in a car priced this high. It needs to at least match the refresh Tesla Model S at 407 and should even be higher. Especially, when you consider the ranges published are not even close to what you get in real world driving. Also, in Midwest the charging infrastructure is still very weak and even it was stronger, I don’t want to do more stops because range is so short.
