I know this must have been covered somewhere, but I could not find it. If I'm on a road trip with the trunk full, and I need to use the spare, where will the flat tire fit? After it's flat, will it fit in the frunk where the spare was?
That is a very good question. I don't believe it will fit in the frunk but I'm not positive. That said once you remove the spare from the frunk you will have some space to move stuff from the trunk and hopefully then you can fit it in there?? Hopefully you also have an old blanket you can wrap it in so as not to stain the trunk area.I know this must have been covered somewhere, but I could not find it. If I'm on a road trip with the trunk full, and I need to use the spare, where will the flat tire fit? After it's flat, will it fit in the frunk where the spare was?
The frunk has 2 sections. The spare I have fits in the bottom section of the frunk tilted so that the cover fits cleanly over it and allows me to use the space on top for additional storage.I know this must have been covered somewhere, but I could not find it. If I'm on a road trip with the trunk full, and I need to use the spare, where will the flat tire fit? After it's flat, will it fit in the frunk where the spare was?
Depending upon the severity of the puncture, you could use the Lucid fix a flat package to insert the goop and then inflate the tire back to where you would be able to drive it. This is the solution I have chosen and I keep the stuff in my trunk. No spare.Well, this would prevent me from taking the car on a road trip where I would be out of cell service during part of it, even with the spare.
On a related note, if you can get roadside assistance, what do they do? Do they have to tow you somewhere where you can purchase a new tire (assuming you don't have the spare)?
Had this conversation when I used the goop on my Porsche. Once you use the goop, the tire is no longer usable.Is there any more information on this? There isn't any information on the webpage. How long (far) can you drive on a tire that has been fixed this way? And will the tire be able to be repaired after this is used?
I believe that is correct. But I've also been told the Pirelli PZero tires (21" in my case) should never be repaired (something to do with the foam inserts built into the tire) so a replacment is required. If you purchase the America's Tires certifications they will replace the tire at no cost anyway.Had this conversation when I used the goop on my Porsche. Once you use the goop, the tire is no longer usable.
That was true some time ago and might still be true with some products. Fix&Go is what Lucid sells and their product can be cleaned out of the inside of the tire with water - the company states it takes less than 10 minutes. The tire shop just has to be willing to deal with it.Had this conversation when I used the goop on my Porsche. Once you use the goop, the tire is no longer usable.
The tire shop just needs to either peel the foam back or make a small cutout where the puncture is to make the repair. It’s been reported on this forum that people have gotten punctures repaired. It’s been reported that Discount Tire will do it (and it’s free)I believe that is correct. But I've also been told the Pirelli PZero tires (21" in my case) should never be repaired (something to do with the foam inserts built into the tire) so a replacment is required. If you purchase the America's Tires certifications they will replace the tire at no cost anyway.
Thanks for the update. Learned something new.That was true some time ago and might still be true with some products. Fix&Go is what Lucid sells and their product can be cleaned out of the inside of the tire with water - the company states it takes less than 10 minutes. The tire shop just has to be willing to deal with it.
It can be done, but it technically goes against the manufacturer's recommendations and voids the warranty.The tire shop just needs to either peel the foam back or make a small cutout where the puncture is to make the repair. It’s been reported on this forum that people have gotten punctures repaired. It’s been reported that Discount Tire will do it (and it’s free)
Exactly!!It can be done, but it technically goes against the manufacturer's recommendations and voids the warranty.
If you do it, watch out for the sound of 'dead spots' as you drive. If you hear nothing, you're fine. DT will happily replace it though if you have certs.
It's pretty much a tow and sucks. However, you can use a can of fix a flat type goo and an air pump and that'll work to get you where you need to go.I'm curious about people's experiences with flat tires. At the moment, I don't have a spare. When you have a flat, do you call Lucid service, or someone else (I have AAA as well)? Since there isn't a spare, so they attempt to repair it there, or do they have to tow the car. Must admit, I'm a little nervous about not having a spare, even though I can't remember the last time I had a flat tire.
I highly recommend buying a spare time for your Lucid Air. There is no really good options if you don’t have one - you can use Fix-a-Flat temporarily for some tire issues, but this isn’t a very good solution. One thing nice is the spare I bought fits in the lower side of the frunk and the cover fits nicely over the top. It also included all the tools you need to change the tire, including a jack that works well with the weight of the Lucid. I purchased mine through EV Sportsline. The entire kit cost ~$500 total - well worth the investment and peace of mind, especially if you have 20” or 21” rims that are easily damaged.I'm curious about people's experiences with flat tires. At the moment, I don't have a spare. When you have a flat, do you call Lucid service, or someone else (I have AAA as well)? Since there isn't a spare, so they attempt to repair it there, or do they have to tow the car. Must admit, I'm a little nervous about not having a spare, even though I can't remember the last time I had a flat tire.
I also highly recommend a spare. Lucid service will only flatbed the car to the nearest tire shop you specify, which doesn't help at night. I purchased the spare last winter (fits nicely under the frunk shelf) and two weeks later hit a pothole that caused a flat in a snowstorm at night far from home while going to an event. Would have been SOL without the spare but service showed up and had the spare on in 30 mins allowing me to make it to my event. One interesting note on this is that when I contacted Lucid roadside they advised that they could only tow the vehicle, even though I had a spare, so I ended using roadside assistance through my insurance instead.I'm curious about people's experiences with flat tires. At the moment, I don't have a spare. When you have a flat, do you call Lucid service, or someone else (I have AAA as well)? Since there isn't a spare, so they attempt to repair it there, or do they have to tow the car. Must admit, I'm a little nervous about not having a spare, even though I can't remember the last time I had a flat tire.
