Based on Lucid's answers: They have stated the Pure AWD uses the same battery modules and motors as Touring. They have stated that the Pure AWD is lighter (due to less features) than but have the same drag as Touring. They said that the Pure AWD was software limited vs the Touring to differentiate the trims. They have said that Touring will be their most efficient trim for Air.
Pure's combination of weight, power, and drag should have given it a few extra miles per kwh when they tested it vs the Touring, but it is not, why is that? Typically with all other EVs, the lighter, less power trims have more range
Touring has less power than GT is due to the fact that Touring has 18 battery modules vs GT has 22 battery modules. The battery size has an effect on its power, as well as its max charging speed. However, the Pure has the same exact 18 battery module set up as Touring.
