no power frunk for peasants
Touring has power frunk standardDoes Touring get power trunk? Surprised not standard.
Did anyone actually confirm for Pure either based on official statement from Lucid folks (SA or DA) or whoever were present in the launch party?Touring has power frunk standard
The lists of standard equipment for Pure and Touring @Halodde got in Sept seems to be 100% accurate
I wish I had seen all these messages about the frunk before the event last night. Sorry dudes!Did anyone actually confirm for Pure either based on official statement from Lucid folks (SA or DA) or whoever were present in the launch party?
One of the message I saw last night from user Pax that hardware of Pure and Touring are same (as per SA). So, I'd expect Pure to have power frunk if Touring has (which is now confirmed).
No problem. Thanks for representing the community.I wish I had seen all these messages about the frunk before the event last night. Sorry dudes!
I believe Pax was referring to the drivetrain and batteries when comparing Pure AWD and Touring because of their differences in HP, range, and efficiency. Both Pure AWD and Touring have the same 18 module battery pack and include the same dual motors.Did anyone actually confirm for Pure either based on official statement from Lucid folks (SA or DA) or whoever were present in the launch party?
Possible. The only material update yesterday was the EPA rating, rest of the information for AWD version didn't change for what had known for months. RWD is still up in the air.I believe Pax was referring to the drivetrain and batteries when comparing Pure AWD and Touring because of their differences in HP, range, and efficiency. Both Pure AWD and Touring have the same 18 module battery pack and include the same dual motors.
Yes, it willDoes Touring get power trunk? Surprised not standard.
I think there is an option for a front horn and another for a rear horn. I'm sure I read that somewhere ;-)After mentioning the many features of the Air, my wife said, “does it have a horn?”
You're not going to be able to test drive the Pure, right?Well I am going to test drive the car again on the 22nd, going to compile a list and see what's what.
They have the same native architecture but because of the fewer modules, it results in 7xx v architecture and a max charging rate of 250kwh. 200 mi of range in 15 mins when fast charging was the tagline. RWD Pure will be likely comparable but probably not exact.does anyone know if the touring/pure awd both have a 900v architecture or is it lower due to less modules? also curious how the rwd pure stacks up in that too
700vdoes anyone know if the touring/pure awd both have a 900v architecture or is it lower due to less modules? also curious how the rwd pure stacks up in that too
I hope they keep the same battery size for the RWD Pure. It should help get a bit more range due to the small weight reduction and only one motor consuming power.They have the same native architecture but because of the fewer modules, it results in 7xx v architecture and a max charging rate of 250kwh. 200 mi of range in 15 mins when fast charging was the tagline. RWD Pure will be likely comparable but probably not exact.
I have never been so torn between colors of an automobile. Cosmos silver looks classy. Quantum grey looks shiny. Fathom blue looks like it is unique and will have more of a luster than a shine.I saw Cosmos Silver first time yesterday. As chameleon as Zenith Red, it seems it too changes color subtlely based on intensity of light.
