- Apr 11, 2022
- San Diego
- M4 Cab, X5 50e, Palisade
I must respectfully disagree here.McMaster-Carr is spectacular.
But, as @DeaneG said, you may need to use chair lugs instead, If your electrician doesn't have the right tool for compression lugs. Chair lugs are totally fine; pass code and inspection and everything.
Recently, my Lucid home charging system started to have a problem: the cable and handle were extremely hot during charging. I expected them to get warm, but not over 160°. I contacted Lucid and discussed it with them. They had me open it up and take a picture of the inside. As soon as they noticed the chair lugs, they said that the installation is incorrect, and the compression lugs are required as per the installation instructions. This is despite the fact that the voltage was proper at the lugs and they themselves were nice and cool. My electrician (25 years in the trade) told me that this is ridiculous, this installation is to code, and he feels that the contractors are the problem with the system. By the way, he almost exclusively installs car chargers, although this was his first Lucid. So… Where to go from here?
After several calls to Lucid, I finally got them to agree to replace the charger. My electrician came out and installed the proper compression lugs using his hydraulic tool. He had to special order them so they would fit… The larger 2 gauge lugs have a very large hole in them so the screw the Lucid charger provides fell right through the hole, and my electrician told me that it is inappropriate to use a simple washer at a 100 amp connection. He was able to find the correct ones and now it has been reinstalled. I sent the old charger back to Lucid and I hope that they are able to find what the real problem is.
TL;DR if you install the Lucid charging system with chair lugs and a problem arises, you may have trouble getting warranty service from them. I got lucky… But only after I pushed a little harder than I should have needed.
Old and new pics below:
