My question is when charging my Tesla with 80 Amps the fan to cool the batteries rarely would ever come on the Lucid fan is always running when I charge even on a 15 amp circuit is that right that the fan is always running?
It's just a little circulating pump, this little HW circulating pump at Amazon consumes 14 watts.Pumps, on the other hand, tend to suck up amps, especially compared to fans. Since Lucid batteries are cooled using liquid filled aluminum cooling structure, at least according Rawlinson in his battery tech video, I would assume that Lucid uses a pump to move the liquid to a radiator, in which a fan blow are accross to cool the liquid. Thus, you may have both a pump and a fan working. I would think the pump would be to major ampere draw.
The battery cooling fan uses a lot of power. You must be using a 110v circuit. A 220v at 40-50 amps will be much faster.Question
Does anyone have problems charging when its warm in the garage?
I normally get 3 miles of charge per hour at home and now with the heat in Wisconsin I'm lucky to get 1 mile an hour.
You may want to call Service and have it checked out. So far no issues charging with my 220Volt.Its been days on the charger and the batteries are not cooling down?????
Read the thread Hot Topic. It discusses this exact problem.Question
