- Mar 7, 2020
- Naples, FL
- Model S Plaid, Odyssey
- DE Number
- 154
- 033M4EXG
They replaced our rear drive unit along with the HV battery.
What's your VIN? Replace the last four numbers with XXXX if you want for privacy. I see you submitted a survey but the VIN was incorrect.Just had HV battery replaced. Manufacture date: 9/22, Delivery date: 11/22, Odometer: 21,543. Had "DRIVE SYSTEM WARNING" on cockpit screen that did not go away after a "hard reset" requested by CS. Car flat bedded to Costa Mesa Service center for further diagnosis and fault found in HV battery. Service invoice attached for your own edification. Do not take a "warning light" lightly. Could have converted to a "DRIVE SYSTEM FAULT" and the situation could have been much worse if I was driving the vehicle.
Frank told me about that theory. I do have a "X" car.I've heard a theory that the VINs that have an X at position number 9 have the best batteries. You have a 9 there. Who knows. I have the same production month as you, 33,000 miles on the original battery. Time will tell.
Mine has a “0” in ninth position and had to have HV battery replacedI've heard a theory that the VINs that have an X at position number 9 have the best batteries. You have a 9 there. Who knows. I have the same production month as you, 33,000 miles on the original battery. Time will tell.
Good evening,I am conducting a survey to determine the frequency of HV battery replacement. I'd like to zero in on model, date of manufacture, etc. I would appreciate that all members take this survey, even if you have not needed a battery replacement so we can get an idea of frequency amongst our members. Thanks!
Survey Link
