Demosthenes
- Mar 22, 2022
For those who want a phone mount that is unobtrusive, I tried this one that you can hide completely behind the glass cockpit:
TechMatte Magnetic Phone Holder... https://www.amazon.com/dp/B08YR1BMLW?ref=ppx_pop_mob_ap_share
I think it works reasonably well and seems to hold my phone very securely. Simple brushed aluminum finish, reasonably aesthetic. You can run an L-shaped charging cable under the central console and then upwards, keeping it mostly out of the way and mostly out of sight. When not in use, you can rotate the holder so that it’s completely hidden from view.
In this position, I suppose it could be used as a dash cam or for video calls using the front facing camera. If your phone isn’t magnetic, it comes with an adhesive magnetic ring that you can stick onto the back of your phone or case and it sticks strongly to the holder. Can use in both vertical or horizontal orientation. There’s probably some fancy one that can do wireless charging as well but I didn’t look too hard and this one only costs like 15$.
