All owner initiated resets are considered soft resets. A Lucid tech can do a hard reset which I think involves physically disconnecting something (so maybe a power down?).
Turn Signal method1: Unlock door, open door, turn on turn signal in either direction, exit car, close door, lock door, walk away far enough for fob/mobile key to not be detected by car and wait for blinker to stop. Car has been reset. Note that the blinker is simply a timer which ensures we don't unlock the car before the reset completes.
Key Card method: Exit vehicle, close door, place key card above the B pillar camera to lock the car and walk away for a few minutes (a tech told an owner 10 seconds). Key card locking supposedly disables proximity sensing so you can stand near car and you may need to unlock manually.
Turn signal method1 and key card are Lucid provided/approved ways to reset the car.
The following are owner discovered/provided ways.
Bobby switch profile method: On right most cockpit panel screen, tap top left icon, switch to another profile, switch back to your profile. I think this is specific to screen/infotainment issues. @Bobby should correct/expand on this if required.
App car lock: Bring the Lucid app up, open door, lock car via app, close door, wait a few seconds, unlock normally.
Turn Signal method2: Follow directions for method1 BUT don't exit the car. There are actually 2 versions of this. One where you remain seated and the other where you lift your rear off the seat bottom to simulate exiting the car when you close the door and lock it (you can sit back down after the car is locked). You may need to put your fob in a faraday pouch and/or turn bluetooth for mobile key off.
Pilot Panel: The safest way to fully reboot the car is to press and hold the Air logo in the about tab in the settings menu on the Pilot Panel for 20 seconds.
