Hi, everyone.
A suggestion from @xponents during an earlier conversation about calculating a more accurate estimated range got me to thinking: "I could make a Shortcut for that."
For anyone with an iPhone (Sorry, Android and Alexa folks. Someone else will have to make this for your platforms.) you can download one of the files linked below to add a Siri Shortcut to your phone.
Tap the correct corresponding link below ON YOUR PHONE to install the correct shortcut.
Once installed, you can invoke Siri with a "Hey, Siri" and then say "Touring Range." (Or GT Range. Or Dream Range. Whatever trim corresponds to your car.) Siri will prompt you for your current percentage and efficiency (Tap the Trip button on your Pilot Panel to see your current mi/kWh for efficiency.) Then it'll do the math and tell you how far you are estimated to be able to go.
If you are using CarPlay, this will also work while driving. Just hold down the microphone button and say "Dream Range" or whatever your trim is called. If you wish to change the phrase needed to invoke this shortcut, just rename the shortcut in your shortcuts app.
Calculations are based on the simple formula shown in the FAQ section of LucidUpdates.com. (Thanks to @Bobby for posting this info.) I suggest you read up there why this is a better way to go than relying on Lucid's estimated miles.
Touring:
https://www.icloud.com/shortcuts/ca136f594f7541209588179dea17ea46
Pure:
https://www.icloud.com/shortcuts/e08b0129d8db41e2afc6b1ac68733bd5
GT:
https://www.icloud.com/shortcuts/5ebc2970da3940e88ba4849e64cbca9b
GT-P:
https://www.icloud.com/shortcuts/36c735fca3094f80830edc216ca7c5b8
Dream:
https://www.icloud.com/shortcuts/e2ab3bb84c5f4bdd894eb7329c207431
Touring:
Pure:
GT:
GT-P:
Dream:
