Thank you again for posting this. It does work as described. My notes:Here is the long awaited information! Instructions for the mirror tap...
Here is the hardware I used. It's a 3 pack and the smallest pins fit.
You can release the front end of the plastic mirror cover using a pry tool from the middle where there is space (yellow arrow in photo) then pulling down on the sides.
NOTE I was only able to release the front end that touches the windshield which is enough. I was not able to release from the mirror end but it wasn't necessary.
The mirror tap goes red to red, black to black. Nothing goes in the brown wire pin.
The mirror tap photos are taken from the windshield side, facing in to the car. Both photos show the mirror tap already inserted.
1. when you pry off the trim piece, yes use a trim pry tool and make sure to put the tool in between the trim piece and the housing below it, NOT between the windshield itself and the housing. It's impossible to see, but you can feel for it (use fingers to pull on the middle of the trim piece to make a gap). Does take some force - pull center and passenger side corner down. That does allow enough access for the mirror tap.
2. Putting it back (after the wave of relief I got when I was able to pull off the trim, worried I was going to break it) is the hardest part, as described. The thing is, I was thinking - removing it was so easy, so I'm just gonna pop it back in and be done! NOT true. Take your time. As has been noted, the clips deform easily. Make sure the back clip is lined up (there will be some rotation you have to do with the trim piece to line it up) and make sure the front clip is lined up and not deformed. In my haste, I kept smacking the trim piece, just thinking it was going to "find home" itself - just made things worse. Had to break out needle nose pliers to fix the clips, took my time (with many times my forehead planted in the windshield) before it would line up and fit in. TAKE YOUR TIME and do it right the first time. They are VERY easy to deform.
My V1 works great after the install. Just used the suction cup mount that comes with it (transferred from the Tesla S we had). With the ease you hit illegal speeds in the Lucid Air, better to have the warning you need to not get nailed by "Ol' Smokey." Thanks Peegh for the pics.
