Seattle to LA road trip. 7 EA charges 5 plug and play worked, 2 needed activation from the app.
Zero problems
Zero problems
It is not okay by any stretch.Since the stations on both sides of him are in use without issue, seems ok.
You don't know who was parked how when he got there. Charging cables and the spaces don't always align for different cars with charge points in different locations. I've had to straddle a strip due to how someone else was parked and also with the shorter cables having to park outside the lines so the cable would reach. With those long cables they should re-stripe with the charge in the center of the space.Doesn’t make it right. If it were the old stations without the long cable then he’d be taking up 2 chargers.
Are you suggesting that he was forced to park like that?You don't know who was parked how when he got there. Charging cables and the spaces don't always align for different cars with charge points in different locations. I've had to straddle a strip due to how someone else was parked and also with the shorter cables having to park outside the lines so the cable would reach. With those long cables they should re-stripe with the charge in the center of the space.
Some of the EA stations have drive thru spaces so you can approach from either direction based on which side the charger port is.
That is a nice set up.View attachment 7518
Yes, some chargers are awkward to position your car to get the cable to reach. I’ve been in those situations where I’ve pulled in behind chargers etc. to get them to reach. These chargers are not like that and he’s in an ID4 which has the port in the ideal location similar to Tesla.You don't know who was parked how when he got there. Charging cables and the spaces don't always align for different cars with charge points in different locations. I've had to straddle a strip due to how someone else was parked and also with the shorter cables having to park outside the lines so the cable would reach. With those long cables they should re-stripe with the charge in the center of the space.
After a year of charging on the road with about 8k miles on road trips, I have scene many things that were once hard to believe.Are you suggesting that he was forced to park like that?
Hard to believe.
You can always use other charger systems while waiting for EA to get its act together. They just won't be free.The more I read about EA, the more nervous I feel about leaving the Tesla ecosystem. Which is a shame, because Musk is a ...
But I need reliable charging for road trips - we drive up and down the East coast with some regularity, and the idea of being stuck because of an EA fail is concerning.
Lol, good idea.Maybe we need to somehow get Elon to tweet about how much better the SC network is compared to EA for the mainstream media to actually report on how bad it is and give EA a PR nightmare. Nothing else seems to work these days…..
