Beyond the Charging Curve: What Are Your Real-World DCFC Speeds?
My point is only that if OP has *never* seen these speeds at low SOC after preconditioning, there is something wrong with their GT.
If you also have never seen these speeds in a GT, there is likely something wrong.
I don't pay too much attention to it. It seems fairly consistant in 35 minutes to get from 10-80. I know I've gotten low 200's and it seems to hoover around 150 for a while. 2023 Pure AWD. I'll watch on the next road trip (Christmas week).
The Pure would max out at 250kW, so that’s solid.
It’s not anecdotal for Pure/Touring/GT. It’s fact. There are plenty of fully preconditioned charge curves posted everywhere and you’ve seen yourself that they charge significantly slower. Your GT-P experience isn’t relevant to our plebeian models 😂
I don't think we are doing
It is absolutely anecdotal for a GT. I have driven and charged GT loaners. I regularly get above 250kW in them, and it doesn’t charge much slower than my DE (it does a bit, but not super noticeable).
I cannot speak to the Pure/Touring as I haven’t charged one. That’s why I really want to take this Touring loaner and charge side by side with @LucidDropkick
I have a 2022 AGT. 90
Random example from Reddit:
Sure, it ramps down quickly, but *nothing* like what @LucidDropkick is describing. He has never seen these speeds at all, which is not a GT problem.
I responded to @LucidDropkick's post. I relayed my own charging experience at EA. I am at a loss as to why some moderators are calling the reported actual experience at EA charging stations (vis-a-vis, the achievable charge times and power delivery) are "anecdotal". Can you guys elaborate and enlighten us?
Let's get a few things grounded:
> the determinants of how fast you can charge any EV is not just the optimal (theoretical) charging curve. The performance of the chargers, climate, balancing/charger-throttling, are all modulating factors.
> the AGT charging curve below is from OoS. Presumably, the curve was generated under controlled conditions wherein there were no (little) intervening factors/limiters from the charger.
> OoS's curve and the reddit data you quoted are not that different. Roughly speaking, if you did the math, the data (OoS curve) suggest it takes ~27m from "zero" to 80% SoC. Whilst, the reddit data suggest (extrapolating) ~35min from 12% SoC to 80% SoC. Both with preconditioning.
>My road trip data indicate my 5%-10% SoC start to 80% SoC is between 50m-60m on EA chargers. I saw little discernable differences between 150kW and 350kW chargers.
> I am not suggesting the AGT charging curves cited above are wrong when done under strict control circumstances (perfect preconditioning, favorable ambient temp, no throttling by the chargers, etc. etc.). Reality is, in practice, you don't get the theoretical charge performance; not because the OoS charging curve is wrong, but you can't replicate the exact circumstances when charging on road trips. Sort of like EPA rating, which applies to a set of laboratory conditions, not real life, right? 😉
Ultimately, what the owner/user care about is what is achievable under real-life conditions.
I have done my said road trip more than 10 times in the past 2 years. As I plan my trips, I'd be up-the creek if I just use the theoretical charging curve and the EPA efficiency. Experience and actual data inform us of reality and possible deviation from theoretical. Data that deviate from theory should be investigated and understood. But deviation from theory does not imply the data is "anecdote" or the observed deviations are simply wrong. Life is not perfect. Even in science, there is theoretical and there is statistics.
OoS AGT Charging Curve::
It’s probably closer to 40 minutes for our Pure/Touring to 80% if you pay attention, but yep, it’s slow
I have put close to 40-50k miles on Lucid GTs and GT-Ps over the past two years. This ultimately boils down to a few points:
- DE, GT-P, and 2025+ GTs have the connotation and assumed charging curves most folks expect. This is generally significantly better than any other trims or model year.
- GT charging times have been posted extensively. Search for it. There are entire threads dedicated to this that I have posted stats for both GT and GT-P with others pitching in Pure and Touring speeds with nice graphs.
- Pure and Touring owners are out of luck. Sorry. Spend more for the GT 25' or buy a Gravity GT if it is such a pain point for charging time.
- Lucid appears to have optimized charging curves to the extent possible given no major updates. Faster charging speeds appear hardware limited (eg. 25' GT refresh).
Our GT had a battery recall after being totaled. Maybe a new battery would have improved charging curves, but we never had a chance. What we did do was buy a GT-P to guarantee satisfactory charging for our needs.
If you experience significant deviations from posted charging curves over several charging stops with battery preconditioning in similar conditions, your only possible improvement is to have Lucid check the battery.
No need to pay attention the e-mail receipts I get from EA give charging time and it's never been that long. As I said I'll check on the next roadtrip.
Because it is literally anecdotal. That does not mean you are lying or didn’t have these experiences, nor am I implying anything of the sort.
“Anecdotal evidence (or anecdata) is a piece of evidence based on descriptions and reports of individual, personal experiences, or observations, collected in a non-systematic manner.
The word anecdotal constitutes a variety of forms of evidence. This word refers to personal experiences, self-reported claims, or eyewitness accounts of others, including those from fictional sources, making it a broad category that can lead to confusion due to its varied interpretations.
Anecdotal evidence can be true or false but is not usually subjected to the methodology of scholarly method, the scientific method, or the rules of legal, historical, academic, or intellectual rigor, meaning that there are little or no safeguards against fabrication or inaccuracy.”
I don’t disagree with anything else you said. In order to get optimal speeds, you need to precondition and set yourself up in an optimal way, and everything has to align.
However, if @LucidDropkick has done those things and has never seen those speeds, then there is something wrong with his car. He lives only a few miles from me. You can trivially create the optimal conditions here, and we have the same temperate climate. He should be seeing those speeds.
That is all I’m saying. None of what I said should be controversial.
And getting back to what I said initially about the true value of pre-conditioning, I’ve never seen a controlled A/B of two cars, as identical as possible, under nearly identical charging conditions (same charger, same approximate time and same ambient conditions). Obviously no two cars are ‘identical’, but we can minimize differences as best we can.
I see merit in such a test to determine the actual value of pre-conditioning vs a theoretical value. This might be of particular interest to road trippers where remaining range could be critical and a few miles shaved off from pre-conditioning could make a difference.
I’d also theorize that the greater the impact of pre-conditioning in a given scenario, the greater the energy use to achieve that state.
here is an out of spec video that directly compares two identical cars in identical conditions charging with and without preconditioning
spoiler/hint: the pre-conditioned car charges quite a bit faster - and does not take dramatically more energy to do so…but it does take some.
but the greater charge rate initially will overcome the extra kwh's consumed for pre-conditioning vs. charge time - honestly your charge time will be much more greatly impacted by EA's highly variable activation/handshaking delay's during initial session start up and stabilization of charge rate…I've lost way way more time moving between stalls at various eA sites that you ever will in terms of extra kWh's due pre-conditioning…
the charging speed benefits of preconditioning dramatically outweigh any incremental kWh costs…and are frankly statistical noise vs the improved charge rate and overall consumption of moving a 5,000 lbs vehicle through the air at 60+ mph…
even _IF_ preconditioning takes more power - let's say 10% power (which it doesn't) on a 100 kWh battery from 100% to 5% that's a 95 kWh charging session for a given driving leg - so if preconditioning takes 10% "overhead" on a 95 kWh consumption run (running the battery from 100% to 5%) - that's 9.5 kWh consumed over that entire "run"…so that's the worse case scenario…let's call it 10 kWh consumed by pre-conditioning
how long does it take to "add" 10 kwh back into the batery at a given charge rate…
10 kWh @ 300 kW charge rate is - 2 minutes
10 kWh @ 200 kW charge rate is - 3 minutes
10 kWh @ 100 kW charge rate is - 6 minutes
now preconditioning is not 10% overhead
it doesn't run the entire driving session
only when the car is about 30 minutes away from the charging stop
so the number above are worse case for pre-conditioning to run for the entire session…
at 4 miles/kwh (I know lucid can do better this is for example - we're not arguing lucids' relative efficiency) - 95 kWh is 380 miles
380 miles at 70 mph is 5.4 hours of driving or 325 minutes
30 minutes preconditioning time is 10% of the entire driving session
if you have 10% pre-conditioning overhead in the last 10% of your driving session - the last 35 miles…
the last 30 minutes of driving is 9.5 kWh is terms of range consumption - add in 10% pre-conditioning overhead but only during that last 30 minutes - that's .950 kWh consumed- or 950 watthours
how long does it take to "add" 950 watt hours? let's call it 1 kwh for simplicity…
1 kWh @ 300 kW charge rate is: 0.2 minutes or 12 seconds
1 kWh @ 200 kW charge rate is: 0.3 minutes or 18 seconds
1 kWh @ 100 kW charge rate is: 0.6 minutes or 36 seconds
2x the numbers above if pre-conditioning takes 10% overhead for an hour before arrival at a fast charging stop…
pre-conditioning is not 10% overhead - teh exact % overhead would be dependent on where the battery's natural temp is vs. ambient conditions vs which direction we need to drive the temp (heat it or cool it)…
in either case the incremental kWh's consumed during the last stages of any given "leg" of a road trip for battery pre-conditioning are fractional in the context of a 70-100 kWh charging session vs. consumption at 3-5 miles/kWh…and given that pre-conditioning doesn't run for the entire "leg" of the battery charging segment - I highly doubt the impact is more than 2 kWh _TOTAL_ - or about 8 miles additional range - and i believe that number to be VERY high - ridiculously high as a matter of fact - it's probably more in the range of 1 kWh or less…additional consumption - which as shown above has at most a 45 second impact on overall additional charging time once plugged in at a high rate of charge…
heck 1 kWh additional consumption is only 6 1/4 minutes additional charging at home on a 9.6 kW EVSE (NEMA 14-50/6-50)…
if you go 380 miles with 95 kWh of battery juice - with no pre-conditioning - then you might need 96 kWh for that same 380 miles w/pre-conditioning - the incremental cost is 1 kWh…
if anyone can characterize the actual "cost" of preconditioning for a given EV and the duration for which that cost will be endured during a driving segement - we can figure out the exact kWh's cost for that pre-conditioning - and then work out the incremental time cost at 200 kWh charge rate…
but you deliver 3.25 kWh every minute @ 200 kW charge session - and 3.25 kWh is 3.5% of a 95 kwh charging session…
so you'd need 16 kwh to have a 5 minute impact on a charging session - and 16 kWh of 95 kWh total is 17% of the entire 95 kWh session - it doesn't cost 16 kwh for pre-conditioning that would be insance and reduce your range by 64 miles…
I'm unconvinced pre-conditioning changes the range or charge time equation in any significant way - and any incremental cost it does incur is noise vs. the overall overhead of getting off the high way -o finding the charging stations, parking, activating the session and getting it up to stable kW delivery rate…
also who's to say pre-conditioning cost anything - the amount of cost of preconditioning is going to be dependent on how far "off" the battery is from "ideal" - if it's 20C too cold - that's a more expensive pre-conditioning session vs. if it's only 3C off of ideal (+/-) and then there is how are ambient conditions helping or hurting? can you use the natural ambient temp to "help"?
the natural running temps of most batteries are pretty close to ideal fast charging temps and after 2-5 hours of running at 70 mph even cold batteries won't be that far off from ideal charging temps…
I've seen no evidence/data from 13 years of EV road trips that pre-conditioning is a significant cost vs. the general overhead of the batteries thermal management system…which is always running.
pre-conditioning is not your problem…
my $0.02 YMMV
OK, a couple of points as I scrubbed through the video. It was not an ideal test because not only was there no true 'preconditioning' in their test cars, but they also didn't use the same charger at the end. Many of us know there can be significant difference in charging rates from one charger to the charger right next to it. It happens and happens fairly frequently. That's why I said in my initial post that the ideal test would be two identical cars, one preconditioned and the other not, charged at the same charger. With that said I'm not disputing the fact that preconditioning improves charge rates, that's a given. My point is at what cost?
With that said, yes, ping ponging is certainly a way to simulate, to a degree, preconditioning. Kyle had no other choice since these cars didn't have true preconditioning. But, and this is the biggie, in their 30 minute drive, this 'preconditioning' cost about 7% SOC. In my book that's quite a penalty and it's why I mentioned this could be very important for those road tripping where the next charger may be 'just' within reach and even then you're not 100% certain the chargers will be operational.
..., this 'preconditioning' cost about 7% SOC. In my book that's quite a penalty and it's why I mentioned this could be very important for those road tripping where the next charger may be 'just' within reach and even then you're not 100% certain the chargers will be operational.
The couple times I've preconditioned and kept track in my Air or Model 3, preconditioning consumed about 2-3% SOC. But it was at California temps, not North Dakota.
Can we try to re-align the discussion/debate on this thread? It is getting rambling. I will try to assimilate some common threads and see if there are any actionable items.
I believe we all have the same objectives:
> to be able to charge our EVs at DCFC stations at the fastest possible rate.
However, not all Lucids are equipped the same. Different models/model years have different charging curves hence, different charging rates.
Other factors , such as pre-conditioning, road-tripping just prior to arriving at a DCFC, climate, DCFC equipment and power sharing, are all modulating factors.
As a starting point: let's agree that, in a lab environment, with a dedicated DCFC, and the vehicle is fully preconditioned, we expect the Lucid to charge in accordance with the charging curve. Let's not debate that point. The corollary is, if your car deviates substantially from its associated charging curve, you might have a battery or Wunderbox problem.
As to pre-condition vs no pre-condition:
> first, let's agree that the charging rate is subject to thermodynamics. Every time you try to counter thermodynamics, you lose. Getting the temperature to an optimal charging temperature (say 85F) maximizes the charging process.
> Does that mean one must activate precondition process for 30min before commence charging? I think the answers is, it depends: [1] you can activate "Preconditioning". It will consume battery. How long it takes depends on the weather, and the battery's temperature. Thus, if my car was sitting around in cold weather and I just roll it into a DCFC station, I should precondition before I charge. Else, it will take longer, perhaps significantly longer. Yes, preconditioning before charging will make the charging go faster, but it will cost you several kWh of energy.
>Conversely, if I were driving on the highway @70-75mph for the last 2 hours, my battery is probably already at an elevated temperature and may or may not need preconditioning. If I've been driving on the highway and my battery is already warm, does activating preconditioning "waste energy"? My qualified answer is "probably no". Yes, the preconditioning heater uses a fair amount of power, but I assume preconditioning is thermostatically controlled. As such, if your car battery is already close to the optimal charging temperature with the highway driving, turning on preconditioning will only consume a small amount of energy to get you to the optimal temperature.
I believe all the above points are straight forward.
What is less understood about DCFC charging speed:
> the charging speed of an EV depends on the model and the model year (thus the applicable charging curve). Hence, if you want an accurate quantitative answer, you need to understand your vehicle's charging characteristics.
> the charging curves are (presumably) generated under ideal laboratory conditions (temperature, environment, dedicate DCFC, preconditioning, etc.). Chances are, you will experience lower, perhaps significantly lower charging performance than the ideal.
> Do all DCFCs dispense the rated power? No, it depends on the equipment, the DCFC equipment configuration (e.g., balancing, station's max power limits, temperature, how many cars are charging (and at what stage of charging), etc.. It is a complex, dynamic, and multi-variable problem. I don't think any casual observer can figure it out. However, one thing is for certain, your charging time will be longer, sometimes significantly longer than the theoretical charging curve implies. In many ways, it is akin to never getting the EPA rated efficiency and range on your car.
As for me, I have a 2022 AGT. I drive long road trips regularly. I charge my Lucid AGT at EA (because I have free charging for 3 years). I typically charge from 5-10% to 80% SoC on the road. The theoretical charging curve for my car is ~30min for such charging. My actual experience is between 50-60min, including the time for DCFC protocol/initiation. I see no tangible difference (when it comes to total charge time) between 150kW and 350kW DCFCs. the EA 150 KW chargers often (slightly) exceed their rated output (say 160-165kWh) and the 350kW chargers often fall well below its peak rating (say 260kW to 300 kW). I am not a big fan of EA, but at the same time, I don't want anyone to think the realizable peak charge rate on the 350kW charger means they are "defective". The REALIZABLE charge rate is a convolution of the DCFC's capability, the vehicle's charging curve, the SoC , how many cars are at that station, what is the max power capability of that station etc. etc.. And a different, day, different station, different initial SoC, different weather, produce a different experience. My feeble mind won't be able to figure it out.
> I have no experience for DCFC charging on my Lucid except on EA. I charge my Rivian R1S mostly on Rivian's RAN (Rivian Adventure Network) stations. These chargers are rated at 300kW. They often deliver to 250kW and higher when you are below 40% SoC. My Rivian battery is 17% larger than my Lucid AGT battery. The charge time (10% to 80%), on Rivian RAN chargers, is about the same as my Lucid, 50-60m.
What is productive:
> on road tripping usage where you are looking to import "range" (as opposed to a bragging-right peak charging rate), a flatter charging curve (as in many German and Korean cars) is more important. It is the area under the charging curve, not the peak, that delivers the range. I don't know if Lucid can rebalance their existing car's charging curves to improve the "flatness". I know Lucid's marketing likes to toute the peak charge rate, but for pedestrian road tripper like me, it has no real value. If technically possible. perhaps Lucid can have two user select modes, Peak Charging Speed, and Road Tripping Charging (flatter charging curve).
> As an experiment, I might alter my routine on my next road trip in my Lucid to start at 100% SoC (from home) and, en route, charge from 10% to 65% and make one to two more stops and see if could cut 30min off my road trip.
What is productive:
There are no actionable items from an owner unless you see significant deviation from the well-documented charging curves posted on this forum for your respective trim and model year.
Everything else is whinging on this thread for a call to action due to normal operation of the vehicle. Lucid could have been and could still be more transparent about charging curves, but no automaker openly publishes their curve. You get charging curves from third party testers and testing it yourself.
Yup, this is definitely the way if you’re in a rush, and why OOS was trying to do 0-60% charges to compete with the Teslas and Taycan in their challenge.
Well I said I'd check next time I was on a trip.
2023 Pure AWD, 45F, preconditioned for 35 minutes, driving between 60 and 75.
Took 30 seconds from attaching plug until charging began
Speed. SOC
238kw. 5%
222kw. 10%
200kw. 15%
187kw. 20%
172kw. 25%
160kw. 30%
148kw. 35%
139kw. 40%
125kw. 45%
112kw. 50%
101kw. 55%
91kw. 60%
82kw. 65%
74kw. 70%
65kw. 75%
57kw. 80%
Total time 37 minutes.
Speed. SOC
238kw. 5%
222kw. 10%
200kw. 15%
187kw. 20%
172kw. 25%
160kw. 30%
148kw. 35%
139kw. 40%
125kw. 45%
112kw. 50%
101kw. 55%
91kw. 60%
82kw. 65%
74kw. 70%
65kw. 75%
57kw. 80%
Yup. That’s pretty much best case for Pure and Touring.
It was at a 4 stall EA station and all the stalls were occupied. Speeds are what I usually see when road tripping. Rarely stop with more than 10% and usually need ~35 minutes to charge, when I go to 80%.
