How many miles do you have on it? Once you hit 2000-3000 miles the efficiency improves significantly.I am getting way less than 400 miles on my range edition. Maybe in the 375 mile range. I had a Mercedes EQS 580 that got about 360 miles consistently which, I think, is more than Benz's estimated maximum range? I have never exceeded 400 miles in the Lucid. Not even close. I've been thinking about bringing it in for service to see if there is a problem.
Oh ok, yeah I have been wanting to take mine in as well. I live in Cali with all the heat and the A/C being blasted every time I’m driving. I have been tracking how much I get and mine is closer to 280 on a full charge. Just wanted to know if anyone else is doing that low.I am getting way less than 400 miles on my range edition. Maybe in the 375 mile range. I had a Mercedes EQS 580 that got about 360 miles consistently which, I think, is more than Benz's estimated maximum range? I have never exceeded 400 miles in the Lucid. Not even close. I've been thinking about bringing it in for service to see if there is a problem.
280?! on 21s or 19s? Also...you must be driving fast or gunning it all the time. I'm on the DEP with 21s and average 3.1mi/kw which gets me roughly 360 miles consistently.Oh ok, yeah I have been wanting to take mine in as well. I live in Cali with all the heat and the A/C being blasted every time I’m driving. I have been tracking how much I get and mine is closer to 280 on a full charge. Just wanted to know if anyone else is doing that low.
I am on 21’s. I do enjoy the power, but I am not always pushing either, if that makes sense.280?! on 21s or 19s? Also...you must be driving fast or gunning it all the time. I'm on the DEP with 21s and average 3.1mi/kw which gets me roughly 360 miles consistently.
What is your efficiency (mi/kwh)?I am on 21’s. I do enjoy the power, but I am not always pushing either, if that makes sense.
2.9 mi/kwhWhat is your efficiency (mi/kwh)?
Same here. I haven't taken from 100 to 0, but the math suggests you should get 325 miles on a full charge. I'd imagine with steady state highway driving it should be even higher.2.9 mi/kwh
Oh wow that’s amazing, I get nowhere near that type of range.19” wheels with normal driving behavior (not steady 70mph but also not Ben Collins) gets me 3.6-3.8 mi/kWh. Elevation is a huge factor, and uphill on-ramps kill range. So my true range for my location/driving style is probably 430. Even if the EQS and Lucid had identical range under identical circumstances I’d still get the Lucid.
At this point I am going to try to highway only this full charge to see what it gets me, cause street driving with AC is eating my range alive.Same here. I haven't taken from 100 to 0, but the math suggests you should get 325 miles on a full charge. I'd imagine with steady state highway driving it should be even higher.
I’m well over 2,000 miles and have yet to experience this supposed effect. Like OP, my range has been realistically capped around 360 miles. I’m also in Florida so…How many miles do you have on it? Once you hit 2000-3000 miles the efficiency improves significantly.
My range did improve past the 2500 mile mark. The tech said it’s because the physical tightness of the drive unit initially creates some resistance when it’s new that gets broken in over time.At this point I am going to try to highway only this full charge to see what it gets me, cause street driving with AC is eating my range alive.
