- Jun 19, 2023
- Denver - Vail, Colorado
- 2023 AT Cosmos-Tahoe 21"
- F716PEYP
I just installed the update last night and am getting charging started/stopped notifications every hour. Definitely a bug or something along those lines. I have it set to charge to 60% and and it is plugged into the travel charger which is plugged into a 240v 50A 5-60 receptacle with an adapter.
Please don't assume it's a bug. I think you have incorrect wiring and incorrect or improper adapters. Or are very unsure what you have. The numbering is very precise. No such animal as a NEMA 5-60. There is no plug rated at 60 amps, and all NEMA "5" series plugs are used for 120volts only. and a NEMA 5-50 you claim to have is 120v 50 amp rare bird with just one 120v line, neutral and ground. I have no idea how a EVSE charger, rated for use only on 240v 30 or 40 amps could ever work on a 120v - 50 amp circuit.
Last but not least, what adapter and why are you using it. And please have a fire extinguisher handy - electrical rated
