Vehicle Drive Settings use to have a designated Snow Mode. Today’s the first day is started snowing…and suddenly I’m not seeing that mode anymore. Did they move this setting?
Youtube video.Where's that screenshot from?
it 100% has been there.It's never been on there, probably eventually, but i would definitely put the car into standard regen for snow.
I beg to differ! But okay, prove itit 100% has been there.
Youtube video.
I believe if you shake a Lucid vigorously it will look like it’s snowing inside the all glass super structureCool! Which video? And have you had it on your Lucid? I live in a part of the country where snow mode would be very useful. Do you know how it works?
Somebody’s smuggling cocaine in their Lucid!I believe if you shake a Lucid vigorously it will look like it’s snowing inside the all glass super structure
Given this is my first EV, why would you suggest standard regen for snow? ThanksIt's never been on there, probably eventually, but i would definitely put the car into standard regen for snow.
High regen is like aggressive braking which is generally undesirable in icy/snowy conditions.Given this is my first EV, why would you suggest standard regen for snow? Thanks
When did you get your car? I don't recall ever seeing that.it 100% has been there.
That is a great question, does anti-lock braking work with only mechanical brakes or also with regen. It would be great if it worked with regen but do we know fro sure?I also don't see the need to go to a lower regenerative braking setting in snow. The anti-lock braking system of the car should automatically reduce regen to avoid wheel lockup during braking, no matter how much regen the driver has dialed in.
