Call service center. They wil come remove your old fob, program a new one and it will cost you $210.Lost my key fob. How do I replace it? Program it?
Losing a keyfob is never a good thing. All of them cost a fortune. I never could figure out why.Call service center. They wil come remove your old fob, program a new one and it will cost you $210.
I thought $210 was kinda reasonable. Maserati charged me $650 and that was back in 2017.Losing a keyfob is never a good thing. All of them cost a fortune. I never could figure out why.
Is it this device? https://flipperzero.one/ … seems kinda cool albeit a little chunky. What uses have you found so far? Would be good to have a clone of both Lucid and Rivian fobs and NFC key cards.Once I get home, I plan on seeing if I can clone the fob with my flipper, and then that could store my permanent fob maybe. We’ll see.
Was told that total of only 5 devices, except the valet card, can be granted access to the car.Once I get home, I plan on seeing if I can clone the fob with my flipper, and then that could store my permanent fob maybe. We’ll see.
Fine, I’ll emulate the valet card lolWas told that total of only 5 devices, except the valet card, can be granted access to the car.
We had 3 phones and 2 fobs and couldn’t add another phone or fob.
Yes.Is it this device? https://flipperzero.one/ … seems kinda cool albeit a little chunky. What uses have you found so far? Would be good to have a clone of both Lucid and Rivian fobs and NFC key cards.
Cool. Let us know if you can clone the card and key.Yes.
Flipper Zero explained: What to know about the viral hacker tool
Flipper Zero is easy to use, versatile and powerful. Learn how it exposes device communication signals and how those signals could be manipulated.www.techtarget.com
7 cool and useful things to do with your Flipper Zero
Forget all the fake Flipper Zero nonsense you see on TikTok. Here are a bunch of very real and impressive things I've used it for.www.zdnet.com
Now there’s even an “App Store” lol: https://www.theverge.com/2023/7/24/23803600/flipper-zero-app-store-launch
I think that Homelink in the Lucid allows up to 15 different devices.If a garage opener is cloned, does that count as new and add 1 to the number of devices ?
Asking because my garage opener is so antiquated and allows very limited access.
No problem from the Lucid end. It’s my garage opener that’s the problem.I think that Homelink in the Lucid allows up to 15 different devices.
Challenge accepted.I am betting that you cannot clone it. It would be nice if you could though.
Once in a while, when adding a new "remote" I've cleared my garage door openers and re-learned everything we own. It's not that troublesome if your opener is at least new enough to have a 'learn' button on the wall switch....When I linked the Lucid, it kicked out a car that we still have.
Thanks for the excellent suggestion.Once in a while, when adding a new "remote" I've cleared my garage door openers and re-learned everything we own. It's not that troublesome if your opener is at least new enough to have a 'learn' button on the wall switch.
It doesn't take very long because you're just teaching the garage door opener about the existing remotes you already have, not also cloning new remotes (no need to reprogram each car's homelink etc)....May have to set out half a day in the winter to reprogram everything.
Challenge accepted.
