SO, I want to install a radar detector but not an installed detector package, so I can change unit as tech changes. Has anyone tried to do a power tap behind the rearview mirror for this?
Yeah. I'll try to take a pic a little later.So you have a cord running into the center armrest where the USB is?
Shoot. Just realized I took the pics, but forgot to post them. Here they are @amoroso6.Yeah. I'll try to take a pic a little later.
I just plug mine directly into the USB outlet with this:
USB A Male to 12V Car Cigarette Lighter Socket Female Cable Converter 1.2M/4FT https://a.co/d/1zlCYu8
The radar detector plug has a mute button, so I just have it coming straight down, to the right of the pilot panel. It's not the prettiest setup, but it works and I don't care about aesthetics in the car. Not one person who has seen the car had made any comments about my radar detector setup, other than asking what it is. They're all too enamored with the car to notice I think![]()
Right, I confirmed as much with the service manager when inquiring about getting my windshield replaced.I can't remember who, but someone posted that Lucid has gone through 3 or 4 different versions of the windshield. The most recent version doesn't have the signal blocking of the older versions, so there's no interference.
Ask the service manager for your closest service center would be my go to, or email customer service. They'll have you VIN and which version of the windshield you have.I received my car in April from a previous cancellation. How do I find out if my GT does or does not have the metallic coating in the windshield??
How will you know IF your windshield is interfering with the radar detector? Will the detector beep or just not pick up radar?It was previously mentioned several times on this forum that the windshield has a metallic coating that interferes with the use of a radar detector except in the lower right corner of the windshield?? How come yours is working??
Mine alerts slower than it did in my Mercedes but still gives me enough time. It seems to alert sooner for laser and K-pop than Ka band. I hid the wire a bit more than @Neurio, put the detector in the left bottom corner of the windshield, threaded the cable underneath the glass cockpit and steering wheel then ran it underneath the pilot panel bin keeping it stuck to the inside with black 3M adhesive cable clips so you don’t notice it, then looped it under the seat and back up the side of the arm rest to the USB connector also using the 3M clips. Totally low-fi but it works. There was another thread on it where I posted pics I think @amoroso6 if you look for it.How will you know IF your windshield is interfering with the radar detector? Will the detector beep or just not pick up radar?
Post in thread 'Dash cam' https://lucidowners.com/threads/dash-cam.966/post-23123Here’s the thread:
What did you sacrifice for a Lucid Air?
I sacrificed time, all of which is now being spent on www.lucidowners.comlucidowners.com
And see if you can find @hydbob amazing install of his dash cam. Totally can’t see the cable at all.
Standard cord that came with the detector. It's plugged into the converter I linked to earlier in the thread. I will say that it sometimes swings in corners and can hit the pilot panel, so I'm probably going to try to get the cord out of the way a little better. Probably not as much as @bunnylebowski, but it's annoying when the song suddenly changes because the cord hits the screen.Well that doesn’t look to bad, was that cord the standard or did your order a longer one
Thank you. I e-mailed the customer service center. Will await their replyAsk the service manager for your closest service center would be my go to, or email customer service. They'll have you VIN and which version of the windshield you have.
Please let us know what they say as well since there will probably other owners who will have the same question!Thank you. I e-mailed the customer service center. Will await their reply
