- Mar 15, 2022
- AGT, Genesis GV80
And when I try to listen to my music from my phone while in my home office but it is playing in the car?Just turn off passive unlock.
two options: You can turn off Bluetooth entirely on the phone, or you can tap the music widget in the phone control center and choose the output source.And when I try to listen to my music from my phone while in my home office but it is playing in the car?
Why not just turn off Bluetooth while in the car wash?So, I think it's the car. I left the fob at home and was using the mobile key. Went to car wash and was using the "do-it-yourself" one. I got out and locked it so the handles would be in. As I was going around the car washing it, the car continually cycled thru lock-unlock. lock-unlock. I was never more than 2 feet away....maybe 3 tops.
It HAS to be a poor receiver inside the car, no?
Seriously?!?!? You know that’s not the point!!Why not just turn off Bluetooth while in the car wash?
Yeah then you are in fob lifeJust turn off passive unlock.
Seems like the antennae is hyper sensitive then. It's also supposed to stay locked for at least 5 min, more like 10 when you push to lock.Seriously?!?!? You know that’s not the point!!
Same ... since I've started using the bag, battery hasn't died. Will need to keep track when I change battery next, but it has been awhile for me (3+ months)I keep the FOB in a Faraday box about 20 feet from the car. It does the trick!
https://www.amazon.com/dp/B07W94QLKM?ref=ppx_pop_mob_ap_share
When I wash my car, I turn Passive Lock off so that the handles stay open the whole time. I like to call it Car Wash Mode.So, I think it's the car. I left the fob at home and was using the mobile key. Went to car wash and was using the "do-it-yourself" one. I got out and locked it so the handles would be in. As I was going around the car washing it, the car continually cycled thru lock-unlock. lock-unlock. I was never more than 2 feet away....maybe 3 tops.
My guess? The car just needed a few extra seconds, and you just kept pushing doors until it was finally ready at the rear passenger door.Today is like first day I can remember me being able to open the door by pushing a handle when the car is in deep sleep. I also just changed to a bitterant cleaned with rubbing alcohol battery yesterday. So I pushed my driver door that didn’t work, pushed rear driver door that didn’t t work pushed front passenger door that don’t work, then I finally pushed the rear passenger door there was like a 5 second delay but then the lights came on and car was awoken!!
So the key I guess is what door you press. I guess I have to press my rear passenger door strange.
Why can’t all the doors do this ??
Also film mobile key, valet card, new battery, using the other fob, etc.A 90 second wait I could try it I will film it too
How exactly does valet card work when passive unlock is off??Also film mobile key, valet card, new battery, using the other fob, etc.
Valet card works regardless of lock setting.How exactly does valet card work when passive unlock is off??
Well I tried it. It ran about 2 minutes and didn’t unlock from driver side so I don’t think it’s a timing thing. On my car push to unlock on the driver side just plain doesn’t work…
Do we tell Lucid this is a software problem or a hardware problem? Can someone run the same test and have it work on driver side ??
It’s in deep sleep mode that’s a prequusitite
And passive unlock should be off
Video
Yah that didn’t work for me I also have no clue how the card worksValet card works regardless of lock setting.
From the manual:Yah that didn’t work for me I also have no clue how the card works
Yeah so I did that in the video right that didn’t “unlock the car”From the manual:
Hold the Valet card just above the driver's
side center pillar camera to lock or unlock the
doors.
