- Apr 16, 2023
- Southern California
- ZQOO2D7O
I was going to respond the same but your response is perfect.I've had several dings taken out of our two Lucids. It's true that aluminum is more challenging than steel, which I found surprising. However, with so many cars now being aluminum, "dent doctors" would soon be out of business if they didn't master techniques for working with it.
Regarding the hood, there are a couple of approaches that might work for the hood despite the honeycomb panel under it. If the hood has neither a PPF nor ceramic coating on it, some dings can be worked out using suction from above.
Alternatively, sometimes a small hole (or holes) can be drilled in the back layer to gain access to the rear of the dent. This happened with a door ding near the edge of our Lucid rear door where the sheet metal folded back to create a smooth rounded door edge. The "dent doctor" drilled a small hole through the folded flap to access the dent from behind and work it out. He then sealed the hole with silicon, and everything looks fine. That honeycomb under the hood should be able to accept a few small holes without compromising its purpose of stiffening the hood. If the dent is at a point where the hood is bonded to a honeycomb rib, that could be more problematic. But, then again, that's less likely a spot which would have gotten dinged in the first place due to the underlying bracing.
Every time I've had one of the five dings worked out on our two Lucids, the repairman started by telling me it would be difficult, if not impossible, to get a satisfactory repair in that location, either because of access problems or a complex configuration of the sheet metal in that area. Apparently, very little of a Lucid's sheet metal surface doesn't have something structural or electrical behind it. With effort and a bit of ingenuity, though, every repair has been done leaving no sign the ding was ever there.
My wife had a small accident with a bicycle rider who didn't see/care about the stop sign and collided with the driver fender and rolled over the hood. Luckily the bicyclist wasn't hurt but there were three nice sized dents on the hood (fender and hood are one piece). Didn't want to go through my insurance and took it to a very good PDR shop. They were hesitant because of the double walls but they said they would try but couldn't guarantee the results would be perfect. Also warned me they might have to drill access holes for their tools but would use silicon plugs after and the result would be good. The were actually able to repair it almost perfectly without drilling holes but had to remove the PPF from the hood. The only noticeable thing was under direct sun, the infinite black reflects light slightly differently at the repair spots. After replacing the PPF film, the total was $2K - much better than expected. My insurance didn't go up, there is no accident recorded on the car, but everything was out of pocket.
