Dream Edition aiyoooo!
My sales advisor called a few days ago and wanted to know if I were interested in upgrading to the Dream Edition. I told him that my largest concern was the lower range. He agreed that it is an issue.
Magically, this morning, I got the email about the smaller wheels and the improved range. Now I’m waiting for my other suggestions to him: more exterior colors, interior leather choices, and maybe platinum. Also would be nice to get a credit for choosing some of the downgrades like wheels and seating coverings. I also told him I’m not really interested in more performance.
I guess what I really want is my original GT order and quicker shipping, presumably like the Dream edition.
Can it have the 21/22 in wheels in Silver with Stealth?
I think a mismatched spare would be OK for limited use to complete a road trip.
My two data points: I've seen a differential completely ruined by long-term use of two mismatched tires on a mid-1960's vehicle. And I've had a mechanic laugh at me for wanting to shave a new tire to match the diameter of the old one on the other side of the "axle" on a modern car.
Probably with limited use and speed.
On an ICE car I wouldn't think there would be much risk. Those donut spares work, I guess. Never had to use one.
Was that modern car you referenced, an ICE or EV?
However
Just placed the call to upgrade to DE. According to my sales person, this will not affect my delivery date. We're still subject to existing owners at the front of the line and I have an early order, but I'm not an owner.
He tried to look for an "asset #" which might indicate that they are planning my build, but my record didn't have one. I didn't ask if that was something that other owners are already getting on their Gravitys, though.
Still saying something about Spring 2025 for deliveries. It could be weeks away, or months. Or years since I'm not an existing owner.
There's a new forum member -- @PetevB -- who is an engineer and seems to know a lot about these kinds of issues. Maybe he can weigh in on our questions?
Do we know the offsets and widths of of the wheels yet? Without that we can’t be sure if the front wheel will clear the rear without interference, we’d also need to check clearance to steering knuckles if we used the smallest front wheel.
Re diameter the short answer it’s not great to have that type of diameter difference, but if you treat it like a space saver spare and keep speeds and distance down it’s probably ok in a pinch.
The long answer: The front tires are 30.2” OD while the rear measures 30.9. Usable tread depth before legal replacement is 7.5/32nds, so if you had fresh tires on the front and completely worn on the rear you’d be at 30.2” F and 30.5” R. So the rears are nominally rotating 2.3% slower than the front, but could be rotating just 1% slower. The ABS, traction control and stability control are all tuned to look for this difference. If one rear tire is rotating at the same speed as the front the computer sees this as that tire slipping. That’s not abnormal, some amount of slip is expected during even typical acceleration, but the computer will be doing the wrong thing, and braking, stability control, etc will be compromised. Longer ABS panic stops are probably the biggest risk here.
In addition if you did this in for example a Porsche or BMW they’d likely void your warranty, as you’d be be constantly spinning whatever limited slip differential setup is used (wearing friction plates or worse) due to the diameter imbalance. I’m not clear on Lucid’s solution for the gravity at this point; I suspect it will do better I’m not sure.
All that said, however, when you get a flat your rear tire is most likely a little worn, maybe 30.7” on average, while your fronts are most likely 30”. So a fresh front tire at 30.2” almost splits the difference, which brings the rotating speed down to a pretty reasonable number. Even better would be another tire with a slightly larger ~30.4” diameter (maybe a winter tire option or similar). Used on a wheel that clears I’d be comfortable going fairly long distances without worrying about damaging things (knowing performance would be compromised).
If the wheel offset doesn’t work someone committed could look into spacers and longer studs or similar, hopefully not needed. A true space saver spare in the right bolt pattern and diameter would likely be even better at that point, assuming one could be found. You’ll obviously need the jack, etc as well.
Lucid should really have a service with wheels and tires on the shelf and ready to ship nationwide in 24 hours. AAA flat bed to the nearest town and 24 hours later you’d be back on the road at full capacity. Return the wheel/ tires ready when you’re done for the next guy. I’d pay $600 for that every time, cheaper and probably better than having a spare in car, no concern re diameter differences/ performance, etc. Seems a logical step if you really want people to road trip in these…
Good info. Definitely a bookmarked post, saved for future reference.
I did wonder about the voided warranty possibility.
The better range is with 20/21 wheels. The 21/22 (in silver&stealth) will have the original range.
So even with the 20/21 wheel option the Dream Edition still loses 27 miles of range?
Maybe they're gearing the rear motor lower? It will be interesting to find out the reason for all these different range estimates.
With the 20/21 wheels, the DE gets 410 miles of range, so yeah, it appears it loses 27 miles of range from the GT in exchange for the 242HP.
Not all that surprising, considering the Air DE and GT:
21" wheels:
Air DE Performance - 451 mi
Air DE Range - 481 mi
Air GT Performance - 446 mi
Air GT - 469 mi
19" wheels:
Air DE Performance - 471 mi
Air DE Range - 520 mi
Air GT Performance - N/A
Air GT - 516 mi
So in the case of the Air DE Performance, it gave up 18 mi of range for 292HP over the GT on the 21" wheels.
On 19" wheels, it gave up 45 mi of range for 292HP.
And, interestingly, the Air GT Performance (when it briefly existed), gave up 61HP and had 5mi less range.
So losing 27 mi for the DE performance is not unreasonable given the past.
21" wheels:
Air GT - 469 mi
19" wheels:
Air GT - 516 mi
But weirdly enough the DEs actually had better real world range because of the larger/different battery. This time around DE and GT share the same battery right?
I don't know. They haven't announced a new battery, but that doesn't necessarily mean anything, haha
Per @AirDoll, those with Air Grand Touring and didn't order a Gravity but wanting a Gravity Dream Edition time to check your emails
But weirdly enough the DEs actually had better real world range . . . .
Mine didn't because they delivered the damn thing with an accelerator pedal.
I was sent an email to upgrade from GT to DE, my sales advisor advised in email that this was non refundable.
Rather than upgrading I placed a fresh order. as I understand these are fully refundable, is that correct?
Your GT deposit is fully refundable. Just cancel that order. Your DE deposit is not refundable.
I think for DE there is no call to confirm configuration since it has everything so no refund, where as for GT you may receive a call to confirm your config before going to Production. I may be wrong though.
Makes logical sense, I agree with this sentiment.
I think we've all been overlooking the most important questions: will DE purchasers get to request specific sill plate numbers, and will certain numbers be more valuable for resale?
With the Air Dreams, which had even fewer choices, we got final confirmation calls. Granted, that now seems eons ago, but my sales advisor did tell me yesterday that the plan was still to do a final verbal confirmation of the order configurations for the Gravity.
Again looking to the Air Dreams, the sill numbers were issued in order of production. For instance, with the late addition of Zenith Red, those who chose that color (including me) dropped down in the production queue with their sill numbers along for the ride.
Our original Air Dream was No. 154. After it got totaled in an accident, we replaced it with No. 395. Several issues had been fixed in the interim between the two, such as the trunk lid warpage from improper composite curing and the switch to a windshield that allowed radar signals to pass without an untinted patch in the bottom righthand corner. So, at least in my book, the later sill number was the more valuable.
I have some other questions about the Dream deliveries, though:
Kyle Conner says the Gravity will be delivered with Level 2 and Level 3 charge adapters. But will the Dreams also be delivered with NACS home charging cables? If not included, will they be available to purchase by the time of delivery? (They're not yet showing in the Lucid store, although I assume you can make the CCS cable work by using the adapter that will come with the car. But I'd hate to lay out $650 for a CCS cable only to have a NACS cable come out soon afterward.)
Will the Dreams be delivered with "plug & charge" certificates already set up and linked to your Lucid Wallet for Electrify America and Tesla Superchargers? (I'm having our cars delivered directly to the shop that's going to do the PPF wrap and will thus miss out on the delivery orientation Lucid will be providing, so I'm hoping these certificates will be set up either at the factory or during delivery prep.)
If not available from Lucid, I would just buy one from Tesla, although it’s only 32A. Tesla also has a collection of plug adapters - more than Lucid offers for their mobile connector.
