- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
Not having driven a Plaid, does it have driving modes besides normal and track? And do you feel the same even with the air in swift or sprint regarding getting the mass moving?
The Plaid has three driving modes plus Launch Mode, just as in the Air Dream. However, in the Tesla you can set suspension firmness and steering weight independently of the drive modes.
You can feel the additional weight of the Air over the Plaid in all three drive modes. It's subtle, but 450 extra pounds is enough to make its presence known. The Plaid tires are also considerably wider (20 mm in front and 30 mm in back), so the traction control probably doesn't have to cut power as much as in the Air to keep the tires hooked up from a standstill. When accelerating from speed, the Plaid's advantage seems to dissipate, both because the Air is tuned for mid-range acceleration and, perhaps, because traction control has to intervene less to maintain grip.
