- Apr 22, 2023
- Air Touring
I upgraded to 2.8 on Tuesday and the new CCC v2 was successfully installed yesterday at the Rocklin CA service center
Just an FYI that if you upgrade software to 2.8.0 before the CCC v2 upgrade,the upgrade to CPU can’t be done.
I mentioned this too. It’s a new process; they’ll get there.It would have been nice if the service department had mentioned these things.
It makes sense for a broken CCC, which in theory might not allow them to back up the data and restore it. But they aren't doing that. If they could, I assume that they would, but it seems strange that they can't. I would expect diagnostic computers to be able to see settings and data, which would mean being able to save it if they wrote the code for it.I mentioned this too. It’s a new process; they’ll get there.
Funny enough, they do mention it for replacements (as in, a broken CCC) but that info didn’t get put into the “upgrades” doc apparently lol.
I upgraded to CCCv2 on Monday with 2.8.0 pushed after installation. Had to uninstall app, reinstall, unpair-repair, relink fobs, mobile keys, etc with many failed attempts. Then discovered Homelink needed re-pairing, but couldn't find my remote. A new remote and several failed attempts later, finally paired. I haven't seen any improvement in functionality, infotainment system (still need to re-login to TIDAL), except for DDPro: hands-free was good. The only other issue I noted was the screen backgrounds which had been pitch black are now more greyish - not a fan, maybe my cataracts? Don't know if the background color can be changed? I'm hopeful upgrade will give access to future OTAs (tied to DDPro?).My app showed the upgrade right after I dropped the car off. I wasn't going to do it, because I didn't know when they were going to start on the upgrade. Fortunately they did it right away. That had told me that they'd need the car for a few days, in which case I might have done it after the shop closed. Once they started working on it, it started showing a 1.x software version, which I assumed was because they were replacing the hardware, so I'm surprised that the current version is an issue. After the hardware upgrade was done, they started the 2.8 upgrade. It failed a couple of hours later. A few hours after that, the app showed me that the upgrade was available and it completed in about 50 minutes.
Aside from that, people should be aware that the upgrade wipes out a lot of information. Before you do it, check your navigation history to see if there are any addresses that you might need, because they will get wiped out. If they are in your phone's address book, then you'll be safe, but will have to remember to send them to the car the first time you use each one. For any that you haven't saved, you'll need to make note of it. Make sure that you have a remote control for your garage door or gate or anything else, because they will get removed too.
When I picked the car up, I had to reenter my credentials as the primary driver. I had to give the system my home and work address. I had to add Bluetooth for my phone. I also had to add it for the mobile key. The latter failed time and time again. Finally, I went to my list of paired devices on the phone, removed anything Lucid and then tried again. Then it worked. I had to add my PIN because it was gone. The Guest PIN may or may not have been there, so I set one anyway. It had to relearn my face. I readjusted the steering wheel to be lower than I had been using it, to the point that it obscures the title when Dream Drive is on, had it learn my face, and Dream Drive worked smoothly without complaining that it didn't recognize my face. I had already adjusted my seat, but did it with the levers on the side of the seat. I should have used the center screen and pressed "save to profile" because when I got home, it moved the seat back to let me out, and didn't return it the next time I got in. Easy entry needed to be reset, which I had done before that, and would have been better off holding off on. You will need to go through all the Dream Drive options one by one, because they may not be set the way you expected. You might want to go through all options, because I can't be sure whether I missed any. Android Auto decided on its own to have me do something to set things up, and that was straightforward. Then I had to add my garage door back to Homelink. Now I have to go to other locations that were tied to Homelink, and add them back over time. Plus, I need to explain to my wife that it needs to have a profile for her, learn her face, pair to her phone, etc. Then she'll say "what upgrade? Why?"
The car did save the trip odometers and WiFi from before.
It would have been nice if the service department had mentioned these things. Fortunately, I can still remember my address.
