- Mar 6, 2022
- AGT 19"
What leads you to that conclusion?Shop is keeping keys to close to the car.
Its been well discussed on this forum. Car constantly waking depletes the battery. That change is rather highWhat leads you to that conclusion?
Compared to earlier reports I thought 0.75%/day was relatively low (though I do see some reports down in the 0.25%/day).Its been well discussed on this forum. Car constantly waking depletes the battery. That change is rather high
Do you have your mobile key on and lucid app Bluetooth on? I think I am losing more than 10 miles per day and not sure why.When my car is in garage at home I don't have any drain any more, or negligible far less than .75%
Keep keys away or in a faraday pouch. Disable BT on your phone or change the security permission. Don't open the Lucid app. Keep you car in a garage at 70 degrees and your drain will be less than a mile per day.Do you have your mobile key on and lucid app Bluetooth on? I think I am losing more than 10 miles per day and not sure why.
Speculation on my part as my car is still just an ephemeral order, but I think your daily SOC loss may be higher if your SOC is much higher than 80%.Keep keys away or in a faraday pouch. Disable BT on your phone or change the security permission. Don't open the Lucid app. Keep you car in a garage at 70 degrees and your drain will be less than a mile per day.
I disabled the Bluetooth on my phone but should I also adjust the setting of the lucid app? The location is set to always and the app background refresh is on. Thank you for your help.Keep keys away or in a faraday pouch. Disable BT on your phone or change the security permission. Don't open the Lucid app. Keep you car in a garage at 70 degrees and your drain will be less than a mile per day.
Are you using your phone as a mobile key? Also, iOS or Android?I disabled the Bluetooth on my phone but should I also adjust the setting of the lucid app? The location is set to always and the app background refresh is on. Thank you for your help.
IOS and using the phone as mobile key.Are you using your phone as a mobile key? Also, iOS or Android?
10 miles per day does sound like much. Are you connected to WiFi in your garage? I wonder if the car is uploading data overnight.
Yes. There is Wi-Fi coverage in the garage.10 miles per day does sound like much. Are you connected to WiFi in your garage? I wonder if the car is uploading data overnight.
If you are not launching the mobile app, I don’t think it would be doing a lot of background refresh activity. At least nothing that wakes the car too often.
Do you have the Lucid widget on your Home Screen? I have mine on, but it doesn’t seem to be draining the car.
I just checked and didn’t lose much after my phone’s Bluetooth was turned off.Yes. There is Wi-Fi coverage in the garage.
I don’t have the lucid widget but the app’s location is always on and background refresh is set to on. I disabled the phones Bluetooth based on recommendation and I haven’t checked if the vampire drain has improved or not.
Are you near the car with your phone a lot? That would be the only reason Bluetooth would make a difference.I just checked and didn’t lose much after my phone’s Bluetooth was turned off.
It would be nice to keep my phone’s Bluetooth on but wondering how you guys have your phone set up to minimize the drain without turning off the phone’s bluetooth.
