- Jan 31, 2021
- Long Island
- Lucid Pure, BMW i4
- 97KPWDUB
This is probably a very minor issue and, as hmp10 said, it's probably just a faulty tire sensor. Not a particularly uncommon issue in any car.
Hydbob, what are the issues you're seeing?Congrats! No tire sensor issue for me but I have my fair share of bugs that keep popping up. Mainly the parking cameras.
Motor Trend 923-GR Gray FlexTough... https://www.amazon.com/dp/B01A1IJ678?ref=ppx_pop_mob_ap_share
So far they have not responded back on TPMS matter. Which sucks since ots been 3 daysCongrats! No tire sensor issue for me but I have my fair share of bugs that keep popping up. Mainly the parking cameras.
The issue is the TPMS warning light is constantly on. The main display does not show anying but the phone app shows two tires with low pressure. Went to the tire that was not displaying a warning it read 42psi so I filled the tires that had indicators on withe the same pressure. pressure 42psi. still did not resolve matter and infact the main display does not show tire pressure readingsHydbob, what are the issues you're seeing?
. . . it will be addressed after they receive the parts for my replacement issues on the trunk.
I reside in Connecticut. Placed order September 19 2019. My Dream is fully loaded.I received it on November 23Congrats on getting your dream and sorry to hear about the issue. I'm assuming mobile service will take care of this. Please do post here with how that experience is. Meanwhile, if you don't mind posting what state you are in, when the original reservation was made, what specs you got and when you got delivery it would be much appreciated! Welcome to the forum!
There is a paint blemish on the rear spoiler of the trunk lid. The service guys said it can't be buffed out because it's in the metal so they have a brand new trunk coming "soon." I also had an issue with one of the foam noise seals, there is a divet in the seal so that will be fixed with the new trunk.
I would often have similar issues with my MS, from parking camera issues, to backup camera issues to total blackouts of the main screen. Is there a reboot procedure you can use on the Lucid to potentially bring the system back? That would sometimes work on the MS, but other times I'd be without a camera for the entire length of the drive.I referenced it in an earlier post but in less detail.
If you get in the car and engage a gear prior to the UI completely loading, around 50% of the time the parking camera system will fail to load. You still get access to a backup camera but won't have the surround camera or forward camera available for when you park. Parking sensors work for an audible alert but will not give you a visual of how close you are to an object. I've driven enough and parked enough to know which audible tone correlates to distance. But I've reported this to Lucid and it will be addressed after they receive the parts for my replacement issues on the trunk.
Everything I've had issues with are being taken care of or are a software problem.
Is there anything in the manual about resetting the TPMS system? Sometimes the new values, after filling tires to the proper pressure, need to be registered within the TPMS system. The manual generally states what that procedure is. Of course never having seen the Lucid manual, I have no idea what that might be.The issue is the TPMS warning light is constantly on. The main display does not show anying but the phone app shows two tires with low pressure. Went to the tire that was not displaying a warning it read 42psi so I filled the tires that had indicators on withe the same pressure. pressure 42psi. still did not resolve matter and infact the main display does not show tire pressure readings
Wow, does the sound like a Tesla! I remember doing that with certain screen issues.To restart it right now. I have to pull over, park it, lock it and unlock it to get them back.
Not sure. I think hydbob said it doesn't always act like that, so maybe when things are working right everything does boot at once.Seems like they decided not to have everything boot at once. Navigation seems to only boot when you activate it. It should boot and run in background. Car needs to start boot up when it senses you are within a few feet of the car, not when you get in. Seems they want that start up display to wow you, but that doesn't need to work like Windows 98.
Resolved the issue. Over inflated by 10psi (52) waited about 15minutes bleed the air out to 42 psi everything registered and displayed.Is there anything in the manual about resetting the TPMS system? Sometimes the new values, after filling tires to the proper pressure, need to be registered within the TPMS system. The manual generally states what that procedure is. Of course never having seen the Lucid manual, I have no idea what that might be.
