Has anyone located where they placed the OBDII port? Anyone look at the data? Curious if that has been done with any EV?
As far as I can tell, it's in the rear, right side of the trunk under a cover. That's where the service guys pulled data.
Trunk, right side under the panelI am also curious to know where the OBD port is?
Thanks. Do you know which app could be used to look at it?Trunk, right side under the panel
I had asked for that information. There is no OBD portAny further news on this? Has anyone found an OBD post or been able to read data from the ethernet?
And currently only the service center can access the Ethernet data…
I thought so too.May im wrong but isnt there some (recent) federal regulation that anyone or at least non-dealer should be able to access ecu / controllers' / computer fault codes?
The Air does not have a classic OBD II portDoes anyone know where the Lucid Air OBD port is located? See screenshot for shape and pinout. I just got this plug from Progressive to monitor my driving habits and hopefully will give low insurance premiums.
View attachment 5821View attachment 5822
