- Jan 23, 2022
- Air Dream P
- DE Number
- 458
So I started doing some research into the music quality on the Lucid Air and discovered something interesting. When using Tidal via the built-in application, the stream is limited to 320kbps. However, if you use Alexa to play the same song via Tidal, it seams to play at max quality > 1411kbps. This applies to other services as well, Tidal, Amazon Music, etc. If you play the same song using each method, the version playing via Alexa is noticeably better quality. My guess is Lucid limits the stream quality with the built in application so they do not use as much data but is not able to with Alexa. Thoughts? https://lucid324632209.wordpress.com/.../24/media-overview/
