It does seem like the Lucid has a wider operating range than my Tesla Model X. Meaning, my Model X range would start dropping when the outside temp was below 50 or 55 even. It would drop dramatically below 40 and again below freezing.Heating chews up a lot, unless it’s extremely cold, try using only the steering wheel and seat heaters to get better efficiency. If you’re seeing a lot of vampire drain that is not after a DCFC session, make sure your keys are either in a faraday pouch or far from the car, if you have a mobile key setup, make sure the phone is far away or turn off Bluetooth when near the car. Regen set to high, light acceleration off the line, drive in smooth mode and keep top end speed between 65-75. 2.5 is low, but idk how you drive, and we have established that 21” offer a pretty big range hit especially under higher speeds. Also, if you haven’t exceeded to 2500 mile “break-in” threshold, improvement is coming after the motors loosen up.
It hasn't really gotten that cold here yet for me to test below 40 temps. But on the occasions it's been below 50, the Lucid with heating seems to drop less than my Model X did. Not sure if others have noticed the same.
I'm only 2,300 miles into it so can't say this for sure. We'll see in the coming months.
