- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
- 3OKY7YGA
There's probably no point to replacing/rewiring the sub panel, as it would also require a new run of large-gauge wire and involve unnecessary work. Probably better to just make a new run from the main panel for the EV charger. You might want to ask for quotes for options at 60 amps and at 100 amps. Personally I'd avoid a 14-50 outlet. Besides safety concerns, and slower charging, it may not be possible to have a 14-50 installed in your garage if your locality has adopted the most recent version of the national electric code, which requires GFCI on all 120V and 240V outlets in a garage. This new requirement was added for good reason. But EVSEs for EV charging cannot be installed on a circuit with a GFCI breaker, forcing you to hardwire.
