PenguinOpus
- Apr 9, 2022
- 2012 Model S(FE), AGT
I posted my Tesla Model S early-bug-list and I now have time to post this one for Lucid AGT. Several of the items below I haven't seen reported by others. I've retested many of these on 1.2.6 and not seen any fixes.
Date | SWvers | Priority | Type | Problem description |
4/21/22 | 1.2.1 | 1 | bug | Time zone does not correctly automatically set, whether on wifi or on LTE (it keeps choosing EDT instead of CDT). non-automatic gives me EDT when I select CDT.. yikes! |
4/21/22 | 1.2.1 | 1 | bug | lane-departure warning also adds steering wheel resistance with no immediate feedback as to why. Very surprising |
4/21/22 | 1.2.1 | 1 | bug | key detection doesn't happen quickly enough. I can almost touch car before handles appear |
4/21/22 | 1.2.1 | 1 | bug | mobile key isn't recognized (Android Google Pixel6Pro) to open car (even though it is connected), worked 2nd time I tried, usually fails |
4/21/22 | 1.2.1 | 1 | bug | Takes too long for car to be drivable after entering car (software bootup too slow and above mentioned slow key reco) 23 second boot->reverse |
4/22/22 | 1.2.1 | 1 | physical | when non-roll is enabled, the brake engages on stop and the disengage sound is loud and clunky |
4/23/22 | 1.2.1 | 1 | physical | FM reception is not good compared to Tesla. What was HD on Tesla is not HD and fades in/out in Lucid |
4/23/22 | 1.2.1 | 1 | physical | Phone charger on passenger doesn't work |
4/23/22 | 1.2.1 | 1 | bug | No visual feedback anywhere after initiating outbound phone call (via Alexa) |
4/23/22 | 1.2.1 | 1 | design | Having pause button in the middle of volume control is bad (steering wheel, right side), many mistaken pauses |
5/5/2022 | 1.2.1 | 1 | bug | Windshield wipers default back to "off" every time I restart the car |
5/5/2022 | 1.2.1 | 1 | bug | time zone reverts to EDT even when set to non-auto (and manually selected CDT) |
6/6/2022 | 1.2.1 | 1 | bug | If cruise control set to > speed limit, every time a speed limit sign is encounter, you get a message saying there's a "new" speed limit and to adjust. Many times, it was the same as the old limit and should have generated no report |
6/6/2022 | 1.2.1 | 1 | bug | if you forget to reset charge limit down and car charges back to full, then you _can't_ set it back below the current charge. That's especially inconvenient as it forces you to remember this problem at some point in the near future before you charge again. |
6/6/2022 | 1.2.1 | 1 | bug | selecting the Homelink icon after car boots up does _not_ bring up Homelink menu, just activates the general area with the Work/Home nav choices. You are forced to hit Homelink icon again to finally get garage door controls |
5/29/2022 | 1.2.1 | 1 | bug | There is no way to change audio without multiple taps on far right screen. There needs to be direct access from big screen for short-armed people |
5/29/2022 | 1.2.1 | 1 | bug | Homelink is not accessible until >45sec after door handles present. This is far too long even if I just need to close afterwards (let alone open it) |
6/18 | 1.2.6 | 1 | bug | mobile key (Android Pixel 6 Pro) is not recognized until car boots up and unlock command is sent from phone (up to 60 seconds total) |
4/22/22 | 1.2.1 | 1 | physical defect | the driver door closes loudly/rattles (even when gently shutting), noticeably different than passenger door |
4/23/22 | 1.2.1 | 2 | bug | software is slow, takes 1000-2000msec to switch to music view after button is hit |
4/23/22 | 1.2.1 | 2 | bug | Steering wheel Volume control is slow to respond. 200-500msec for visual feedback |
4/24/22 | 1.2.1 | 2 | bug | Manual trunk latch is hard to use. If you pull up, it almost immediately stops moving (because it senses something pulling?). It is very hard to only push the button without any pull. 90% of my trunk opens jam. |
4/24/22 | 1.2.1 | 2 | physical | the steering wheel, right side, volume control is too stiff. This leads to aforementioned false-pauses |
5/5/2022 | 1.2.1 | 2 | bug | radio station next/previous does not limit itself to starred stations, so what good is starring? |
4/21/22 | 1.2.1 | 2 | design bug | car reverts to smooth on restart |
4/21/22 | 1.2.1 | 2 | design | car interiors gets warm in the sun (70deg + sunlight) |
4/21/22 | 1.2.1 | 2 | design bug | "traffic cleared" message should be "traffic clearing" message |
4/21/22 | 1.2.1 | 2 | bug | incoming phone call did not enable in-car microphone/speakers, once |
4/21/22 | 1.2.1 | 2 | feature | use GPS near-home information to open/close Homelink (optionally) |
4/23/22 | 1.2.1 | 2 | bug | Default audio mix is very deep for phone calls |
4/24/22 | 1.2.1 | 2 | bug | user manual is unfindable on lucidmotors.com website (it exists, but only as hidden link on mobile) |
5/5/2022 | 1.2.1 | 2 | physical | windshield wiper motion seems stilted/stiff and not smooth/quiet |
5/5/2022 | 1.2.1 | 2 | bug | windshield wiper auto mode gets too aggressive in staying on, but also too passive to start going |
5/5/2022 | 1.2.1 | 2 | bug | far too hard to change radio station. Must swipe down (slow) and then select from starred |
5/5/2022 | 1.2.1 | 2 | bug | driver attention detection is too aggressive. If I look at front-right dashboard (where warnings appear) while glancing at windshield, it complains |
6/6/2022 | 1.2.1 | 2 | bug | If cruise control is set, speed limit signs are picked up that shouldn't be: a construction sign warning about a _future_ speed limit reduction (Orange rectangle around white SL sign) will change the speed limit the car believes |
6/6/2022 | 1.2.1 | 2 | bug | Alexa can't handle multiple versions of a contact. If there is any duplication, Alexa reports that it can't decide and doesn't offer choices because they're the same (w/o checking to see if they're dups) |
6/6/2022 | 1.2.1 | 2 | bug | Navigation: turn-by-turn directions of I-435 call it "highway four hundred thirty five" instead of "Interstate" or "I" "four thirty-five" |
4/23/22 | 1.2.1 | 3 | bug | |
4/23/22 | 1.2.1 | 3 | bug | 5-8 seconds to load users manual in car |
4/21/22 | 1.2.1 | 3 | bug | drive-away "traffic cleared" message appeared when car in front had not moved at all (happened once, worked the rest of the time) |
4/24/22 | 1.2.1 | 3 | bug | loading user manual on mobile phone (Pixel 6 Pro, Android, wifi Gbit) took 15 seconds... I thought it was broken |
4/21/22 | 1.2.1 | 3 | bug | volume control causes dropouts when on FM and bluetooth (?) |
4/24/22 | 1.2.1 | 3 | bug | when playing music on Spotify, the default view in the upper right screen doesn't show anything about which song is playing, just a generic spotify logo-set |
4/24/22 | 1.2.1 | 3 | bug | when playing music via bluetooth on phone, there is nothing in the upper right screen about what is being played or what controls are available |
5/29/2022 | 1.2.1 | 3 | physical | the block (light?) in the upper center of the back windshield is very distracting as it always looks like there is a car behind me... |
4/23/22 | 1.2.1 | 4 | bug | car in top-down view is not the color of my car, nor is the one in the mobile app |
4/23/22 | 1.2.1 | 4 | bug | Joining wifi, the device identity appears to be the VIN number with no mention of Lucid |
6/6/2022 | 1.2.1 | 4 | bug | (Related) If cruise control is set and there's a construction zone, the car does pick up the CZ speed limit, but if it encounters a un-bagged speed limit sign it reverts to that speed limit. Arguably this is a mistake by the street crew, but the police wouldn't accept that as an answer. It was clearly still in construction zone with one lane blocked with orange cones. |
