I have tried to use the mobile key function car will not unlock when i walk up to car some explain how this works .........I must be missing some thing here thanks
Make sure you 1) actually set up the mobile key and aren't just relying on the app.I have tried to use the mobile key function car will not unlock when i walk up to car some explain how this works .........I must be missing some thing here thanks
Probably better off with fob only for nowI did all that 3 times un paired repaired rebooted phone no go very frustrating .....call support 3 days now and no response.....maybe the update will address Bluetooth kinks we will see but so far fob only
I don't understand why people hate the fob. It's slim design fits perfectly in a pocket with no bulk or discomfort and it works every time.Probably better off with fob only for now
I use the mobile & find it responds faster to the car than the fob.I have tried to use the mobile key function car will not unlock when i walk up to car some explain how this works .........I must be missing some thing here thanks
will give it try many thanks........I use the mobile & find it responds faster to the car than the fob.
So, assuming you did not do this, this is what we did during setup (I have a S22U)
- - Do not pair your phone to the car yet.
- Setup the key fob first
- Once done, move the keyfob away ... I mean away. Or put it in a Faraday box. Or microwave for the time being. (If the car gets a whiff of the fob, the BT link fails. Make sure the fob.)
- Start the mobile key link now.
- Test it.
- Then pair the phone to the car
Hope the above works.
G'luck.
I have mine set to unrestricted alreadyI just found a setting and I think this might help. It was on optimized but hopefully switching it to unrestricted will keep the mobile key running in the background. Hopefully this will also help with the car telling me the Key is no longer in the vehicle and asking me to enter a PIN many times.
Yea, that's a workaround, but the app shouldn't need to be open for the mobile key to work right?If the mobile key works when the app is open, there is an easy and 100% consistent fix for Samsung users. Currently using S23 Ultra but was on the 22 Ultra before, and it's the same steps to fix.
1. Open Lucid App
2. Go to recent apps (either swipe up and hold if using gestures, or press recent apps button if using navigation buttons)
3. Go to Lucid App in the recent apps and click the Lucid icon, and press "Keep Open". You should see a lock on the bottom of the app now, which will stop it from closingView attachment 11632
