- Jan 19, 2021
- None
You are a couple of days late. Already a lot written on what the update is supposed to do and some problems a few are having after the download.
I didn't say it was. Its just there are only a few manufacturers that understand technology in the right way to implement this properly.Computers are not new things... and updating computers is not a new thing... nor are imbedded systems (just a fancy name for a type of computer)...
There is really no valid excuse for such problems... yes, updates can fail, but if the update process is well planned out and implemented, then there is really no excuse for it "bricking" a device. A good system will allow fall back to the previous (last known working) version with a single "atomic" change to cut over from that old to the new... and the boot process should have a means to tell it "don't boot the current version, rather boot into that last known working version".
There is nothing special about the update arriving OTA vs from physical media... that is just a question of how the new system is delivered, not of any inherent risk of applying the update.
Not many systems get this right, but many do.
So, while "modern vehicles" may fall victim to this problem, it is not because there is any inherent reason for them to do so due to being "modern".
Thanks. I eventually figured out after I posted that if you crawled in from the trunk, you probably would have tried to open the rear doors first before contorting your way into the front!They didn’t open from the inside. But the fronts opened ok from the inside
I updated mine in a parking garage 2 floors underground.took the risk last night of downloading 1.2.6 over a 2-bar LTE connection in a hotel parking lot
Well the update from Alex shows that it reverted back to its old firmware version so the car was working like before!Computers are not new things... and updating computers is not a new thing... nor are imbedded systems (just a fancy name for a type of computer)...
I had to do that 4 or 5 times on my Tesla before I sold it to my sister.As we’re in the middle of a road trip and the Nav system was annoying the hell out of me, I took the risk last night of downloading 1.2.6 over a 2-bar LTE connection in a hotel parking lot. The download went fine, although I did have to reconnect to Alexa. (Fortunately other posters had warned of this, so I remembered to look up the password before I left home.)
The Nav system is now MUCH better at finding addresses, but I haven’t yet checked most of the other features.
We are having a great driving and riding experience with the car, with only one hiccough so far. At an Electrify America recharge station yesterday the car did not recognize that charging had been stopped, and it refused to release the charger cable. I was on the phone with EA on hot tarmac at a Walmart in 103-degree heat while figuring out that I had to use the emergency mechanical cable release in such an event.
Not 100% sure if elevation is factored into the calculation yet. When coming back from SF It was saying 12% SOC when I would arrive home. When I hit the Grapevine it went down to 7% SOC when arriving at home.The nav is pretty darn accurate for SOC% remaining when you arrive at your destination. I've tried it on different trips now over 40 miles each and it's always gotten me there either at the % or just 1% more battery used.
Agreed. Same experience for usThe nav is pretty darn accurate for SOC% remaining when you arrive at your destination. I've tried it on different trips now over 40 miles each and it's always gotten me there either at the % or just 1% more battery used.
How do you do the emergency cable release for the charging cable?As we’re in the middle of a road trip and the Nav system was annoying the hell out of me, I took the risk last night of downloading 1.2.6 over a 2-bar LTE connection in a hotel parking lot. The download went fine, although I did have to reconnect to Alexa. (Fortunately other posters had warned of this, so I remembered to look up the password before I left home.)
Open the frunk, and there is a latch/release right above the charging port . You pull up on it and it releases the charging cable.How do you do the emergency cable release for the charging cable?
Check the settings cogwheel on your pilot panel. Should still be thereEarlier today I had a notification that 1.2.6 was available. When I returned home a couple of hours later, I no longer had that notification or any other indication that an update was available. Has 1.2.6 been withdrawn?
Thank you. I’m going to check out the manual release tomorrow. I have generally found EA customer service to be pretty good. The fact that I have multiple calls with them does not reflect well on the equipment.In MPawalek’s post #245 on this thread there is a drawing of the release lever under Step 2 of the instructions. Basically, you open the hood and pull up the black plastic tab just above the charge port.
I got a snotty little lecture from the EA “customer service” chap about not mastering every jot and tittle of the Lucid Owner’s Manual. (I had called EA as a first resort because when I tried to pull out the charger cable I noticed a large crack in the head housing, so I assumed their cable was the problem.)
The fact that I have multiple calls with them [Electrify America] does not reflect well on the equipment.
