Dash cam
Thanks for posting this. I have two dual-channel Viofo A329 that I ordered a month ago and have not got around to installing in two of our vehicles. I will likely tackle the Lucid first. Just to clarify-the camera is connected to the extended battery pack by the USB-C and the battery pack to the trunk 12V, correct? I was going to try to hardwire myself but may just go this route for simplicity (and safety!). Which coupler for USB-C did you get and how long was it (I am not familiar with those)? I purchased my Viofo cameras with the hardwire kit so I imagine I would need no additional kits/wiring with the extended battery packs? Thanks in advance.
The wiring goes from the front cam to the battery pack in the trunk which then connects to the cigarette lighter using the supplied VIOFO cable.
I did not use the hardwire kit; this way it was easy to avoid messing with an EV fusebox.
The battery pack was back-ordered from Blackboxmycar so I installed the original VIOFO usb-c cable which was too short but long enough to plug into the rear usb-c plug at the back of the center console.
FYI, this is not a good place given that Lucid installed the plug in the actual cover instead of inside the compartment and sticks out at a 90 degree angle.
The battery pack had to be ordered with the appropriate hardwire splice that works with VIOFO and that cable seemed rather long although I think it would have been too short to reach the cam as well.
So I just got a coupler from Amazon to connect the 2 cables underneath the passenger seat.
Don’t have the Amazon link handy but it was a pricier coupler (female/female) that was certain to provide power no matter how it’s plugged in.
Apparently that can be an issue with some cheap Chinese junk couplers.
That said, if you have a glass roof, the thickness of the VIOFO cable is still borderline. You will have to remove the center light strip from roof to route the cable. If you have the aluminum roof, it is super easy to route like in any other car via the A-pillar.
I wish I would have taken some picks during disassembly but it’s easy and quick. The only concern was not to break any clips.
The rear camera required the removal of the C-pillar cover on the passenger side; also easy to do but I realized afterwards that Lucid actually forgot to install one clip :( Now it’s not perfect tight until I can stop by the service location to get one.
Good luck!
To clarify my earlier post. There is a hardwire kit for the dash cam and a hardwire splice kit for the battery extender.
I wouldn’t use a dash cam hardwire cable as that needs to be connected to the Fusebox for ignition (switched) and permanent power. Easy on an ICE but I wouldn’t touch that for an EV…
The battery extender hardwire splice cable handles the connection to the camera and prevents it from falling asleep due to low voltage.
Can you link the battery pack and hardwire splice?
That is how you use it. The battery pack has a default input and output, normally both are cigarette lighter connections.
What you do is to replace the output (female cigarette lighter) with a custom hardwire splice kit that connects directly to the dash cam.
In the case of the VIOFO it is a 5V USB-C connection. With other cams it is a 12V brand-specific plug.
But when you have a battery extender, you will never use a dash cam hardwire kit. Those are only used when there is no battery extender.
Not everyone wants to spend another $400 to get a dash cam that runs for a week without stressing the cars batteries but to me it makes the most sense as EV’s still rely on a good old 12V battery to get the car started.
Sorry for the long answer to a short question ;)
Thank you for your posts that clarifies things. I mistakenly ordered battery packs without splicing kit so will need to change/update that. Was thinking I could use the hardwire kits I purchased with the Viofo cameras.
That's common as the battery extender completely changes the wiring setup. I also realized that calling everything a hardwire kit was confusing, hence the clarification.
Here is a pic of how the battery pack wiring. Input is the only cigarette lighter socket in the Lucid; unique location but quite useful for this setup :)
The output is 12V which gets reduced to 5V in the splice cable for the VIOFO.
So I installed this setup in two of our cars this weekend (one our Lucid Air GT). What do you set in your dashcam under the Parking Mode menu? There is Auto Event Detection and certain time lengths? And as I think through this-the dashcam will always run and record until the battery is completely drained, right? Then the cycle starts over when car started/you drive? As I think of my normal commutes they are very short so this might not allow the extended dashcam battery to charge back up...? I am not sure if I can set some limits via dashcam menus to change this. Appreciate any guidance you or anyone else can chime in with.
I was charged $280 for installation of 2 dash cams and an extra $30 for the technician to come to my house to do the installation.
Here are my dash cam locations, though I can't recall if this was the original spot for the rear dash cam. I had to take it off when I got my windows tinted so I just guessed where to place it back; I could probably put it closer to the corner to save space but this hasn't really bothered me.
I installed a Viofo A329 in what appears to be a similar position on windshield as you did, but a large percentage of the view on drivers side of camera recording is obscured by the rearview mirror housing. Is that not the case for you? Maybe yours is lower than it appears in the photo....
The Viofo build-in screen makes it really easy to find the best camera position before peeling off the protection and attaching it to the window. I have no obstruction on the image at all.
I will take a look at the settings and get back to you...
But, yes, you can just record even without optimizing the parking setting. It will just generate a lot of unneeded footage.
Here is a snap-shot of our settings. I mentioned that the event settings is not needed; you could easily select any other of their settings.
Here is our camera on the windshield when taking the pic at roughly 90 degrees. No impairment of the image besides the bad weather ;)
I've purchased a highly-reputed dash cam kit, and read this thread.
I've been procrastinating the actual install because there are like ten crucial steps to do it well.
Has anyone compiled all the best bits of this thread into a single simple step by step guide?
I know there are a couple of variations: rear battery vs passenger fuse box tap, etc.
Maybe this is my calling, to plan my own then share it ultra-streamlined somehow.
I purchased my dashcam over a year ago. It’s still in its amazon wrapping unopened. I’ve been waiting for Lucid to supercede me by installing their own in-house dashcam system, but it feels more and more like I’ve been waiting in vain.
I don’t have the patience, inclination or good luck to install the dashcam myself, and up to now I haven’t been arsed to look around for an auto audio installer to do it.
I just realized, I haven’t answered your question, or added anything of value. I’m sorry.
The only way you can get Lucid to activate a dash cam feature is to get off your arse and get the one you purchased installed. Lucid should activate the dash cam a week after yours is installed.
That’s about right.
Has anyone, maybe in another thread, answer your question for a single, simple step-by-step guide for installation?
Nope. When I get to it (next month, travel) I'll take pictures and share some steps. I plan to do the passenger foot-well fuse tap for power.
