I like to keep the mobile up unit in the car. Buying a smart one is useful to make use of TOU cheap electricity since the Lucid cannot set the time and to have a spare.If the supplied cable can charge at 40 amps, is a wall charger worth it?
Is the Air's ability to set the charge time being considered?I like to keep the mobile up unit in the car. Buying a smart one is useful to make use of TOU cheap electricity since the Lucid cannot set the time and to have a spare.
I would think so, especially for a car in this price range.Is the Air's ability to set the charge time being considered?
Yes but it doesn’t exist yet.Is the Air's ability to set the charge time being considered?
I answered the pros and cons in my post above. Whether it’s worth it is up to you.If the supplied cable can charge at 40 amps, is a wall charger worth it?
I’m sure I’m doing it wrong, but I feel the same. Plus, we are in fire season and you never know when you are going to need to leave in a hurry.Waking up with a “full tank” every morning is so convenient tho!
what is "that" ? Oh, you mean that bag of wires in the trunk? OK, got it.
OK... we want the amazon wall charger to have a permanent cable to charge with. Got it.
So for quick and dirty charging, using Lucid supplied cables, open the garage door to the laundry room and plug right into that 240v, with wires out the open door. Got it: I need to buy a wall charger for it's hard-wire safety, and to keep the bugs out of the laundry room.
Once the electrician comes next week, I can plug the bag-in-the-trunk Lucid wires into the NEMA plug at my new garage sub-panel, correct?
Then when I get the aftermarket wall charger does that go into the NEMA plug?, or should this be hard wired?
Then if Lucid had a wall charger it would be hard-wired to the main panel with upgraded fuse. No plugs.
Wow. That took me too long to sort out. OK so the imaginary Lucid wall charger now costs me twice as much, or maybe I can ebay the extra wall charger I have to buy...I forgot I have to call the electrician again too...wow, I get it now. Thanks guys. Whew. What a week.
Post purchase expenses:
Saran Wrap $10000
Electrician $ 6500
floor mats
wall charger
another wall charger
another electrician visit
what am i missing ?
What do you call the Lucid bi-directional wall charger? A rumor without a name.
I'm calling the fictional Lucid wall charger "Betty"
"Yea we hooked-up. I pinned Betty to the garage wall and plugged in. Got a bit of charge out of it but she ended up draining me.
She has a wonderbox you see: goes both ways."
Also I looked up EVSE. It's at 2 cents. I already did my termites.
For me, with TOU electricity rates, that alone makes it worth it. But keeping the cable in the trunk is also a benefit. The hardwired speed increase at 48A (or 80A, with the coming Lucid Wallbox) is also a benefit. So is the eventual V2H, though less important for me as I have Powerwalls.
The con is pretty much exclusively cost.
That’s correct. You actually don’t *want* home DCFC because it will burn the battery out faster.Somebody can verify but the Lucid EVSE I think also will charge at 80 amps instead of 50 amps. I had my electrician run 100amp wire to a RV hook-up to facilitate the install of the Lucid EVSE. I'm sure we are years maybe decades away from home DCFC
DC-CCS home "fast" charging is actually beginning to be available, but currently only at 15-25kW..... I'm sure we are years maybe decades away from home DCFC
This is an excellent post. I have this same dream. Sisters live in Eppin'. It's around 350 mi .The standing joke with friends is that my garage looks like it's set up to power the entire town.
The car can handle up to 19kW AC if the charging station can deliver it. Actual charging speed is limited by the minimum of either the car's 19kW capacity or by the charging stations' capacity. If your home charging station is set up properly, take a look at the circuit breaker that it is powered from. Multiply the amperage number printed on it by 0.8 x 240 (=192) to get the maximum charging power of your setup in watts. For example, if your circuit breaker is 50 amps, then your expected maximum charging rate would be 192*50 = 9600W or 9.6kW.So before losses Lucid EVSE should be 19kW? I guess that's 10kW more than what car displays at home now.
During my test drive, I asked the Lucid rep if they were working on software that can set the time for charging; he said yes. That said, I'm still going to install an EVSE. I agree with you 100% on Item 7. Plugging a 240v cable constantly would be worrisome for me. My big decision is whether to hardwire or install a 14-50 receptacle. Either way, I'm going with 40A.All of this is answered in the forum FAQ, but:
1) The Lucid “charger” is the Wunderbox charger that is built into the car. However, you’ll hear “charger” overused to mean EVSE because EVSE is so much more annoying to say.
2) EVSE is “Electric Vehicle Supply Equipment.” It is the generic term for the device that regulates the charging, typically third party. For example, Electrify America has lots of EVSEs all around the country. You may hear them called “charging stations”; same idea. There are also home EVSEs you can install, which are the ones like Wallbox pulsar plus, JuiceBox, Chargepoint, etc. *Technically*, the cable the Lucid comes with is also an EVSE, just a relatively dumb one.
3) the Lucid comes with a charging cable (or basic EVSE) in the trunk. It can be used to plug into any NEMA 14-50 outlet (where it will charge at 40 amps) or a 110v outlet (where it will trickle charge *extremely* slowly).
4) the reason to install a home EVSE is two-fold: a) if you hardwire it, it can charge at 48A on a 60A circuit (which is faster than the 40A you’d get on a 50A circuit), and b) you can schedule charging and control it remotely. If you have “time of use” pricing from your utility, the latter point is important so you don’t have to manage plugging in or unplugging manually. You do not *have* to hardwire a third party EVSE and can just plug it into a 14-50. If you do, you don’t get the extra speed but still get the charging automation.
5) if you install an EVSE, you can leave the charging cable or mobile EVSE in the trunk and use it for road trips or emergencies.
6) the Lucid Wallbox EVSE is not out yet, but we are expecting it this month or next month. It will be able to support 80A charging on a 100A circuit (assuming your wiring supports it), and will eventually support V2H (or vehicle 2 home) backup, but not at launch.
7) the charging cable the Lucid is supplied with will work just fine if you have a 14-50 and is all you need; however, be aware that most residential 14-50 outlets are not made for constant plugging and unplugging and are likely to wear out over time. You can install an industrial 14-50 outlet, but those are a bit more expensive.
That help?![]()
Does your wife know that you stuck her with the slowest charger? Is there community property in your jurisdiction?I have a Clipper Creek 100amp charger. My Air consistently charges at 17-18 Kw. Theoretically it could charge at 19.2 Kw, but I have not seen that in real life. In the same garage I have an 80 amp Clipper Creek charger. That one charges my Air at 14 Kw. I have not yet tried using my wife's Tesla charger with an adapter, but that one is on a 60 amp circuit soi I would expect it to be quite a bit slower.
