It's not a matter of driving down to 2% or 0%, it's more about getting a second opinion from other Owners to see if there is a defect or a battery leak in the car that's causing the drain. Or better yet a fault in the car that short circuiting and consuming energy.
After owning couple different EVs from different manufacturer that have 0 to minimal drain and then you have another brand new product from a non-legacy automaker that does have a drain, it's a very valid reason for concern. And the reasons include - this is normal behavior for the car, I have a battery leak somewhere, it's just poor programming on Lucid's part that's causing the BMS system to behave incorrectly, its due to a lack of heat pump, something is shorting inside the car causing energy consumption.
I see. If you're trying to determine if your car is out of the usual range of loss for a Lucid, it sounds like it might be? Most of us who have eliminated the variables of keys and phones waking up the car are seeing less than you, it seems. And for me, even when my phone and fob were nearby, I lost relatively little.
I'd start, though, by measuring this in terms of percentage, not miles. Like I said, miles are nonsense. Not just on the Lucid, but all EVs. Percentage is actually based on reality. Try to determine how many percentage points you lose in a day, for starters. As
@Adnillien said earlier, for most of us, that seems to be about 0.5%? Unfortunately, the car won't give you decimal places, so even if it drops, say, from 80% to 79%, that's not necessarily a 1-percent loss. It's likely at 79.8 or 79.7. The car rounds down, no matter how close to the next integer it is. (Not super helpful.)
So it may take two or three days to determine just how much you are actually losing per day.
If your car keeps showing a full point drop every single day, then you may have some other factor at play that is draining your car faster than the rest of us.
