- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
The car went to sleep and locked the doors while my wife and I were sitting in the car having a snack. Puling the door knob to its normal position did not open either door. We called the Lucid Customer care and she explained that the door knob has two positions . Position one activates the 12V latch. Position two is a hard pull of the knob, pass the normal travel, and it is a mechanical release. Unfortunately it is very hard to pull, so unless you have been told and have tested, it is unlikely that in a panic situation you would pull hard enough to activate the mechaical latch.
This approach of a mechanical backup is becoming the norm for cars with electric door switches. Our new Tesla has a button you push for normal door opening and a mechanical tab at the leading edge of the armrest that you pull up to open the door mechanically in the event of power failure.
However, as with the Lucid, its presence is not obvious, as it's formed to look like part of the armrest. You would have to know it's there in order to use it.
I think the easiest solution would be for an audio signal with a video warning notice to pop up on the screen just before the car powers down, explaining how to power the car back up and how to open the doors manually. This might not help in all situations, but it would help during a normal power-down.
