Custom power limits for AC charging can now be set.
Lucifer
Lucid Grand Touring
As of Lucid Air software version 2.8.0, you can set an Amperage limit for AC charging. Once configured, the custom power limit activates automatically when within 160 feet of a saved location. This is a new option on the charging screen. When the Lucid mobile charging cable is plugged into a NEMA 14-50 receptacle, its Amperage limit is fixed at 40 Amps. If it is used on an existing circuit with a 40 Amp breaker, the Amperage needs to be throttled back to no more than 32 Amps which was not previously possible. Continuous electrical loads, such as charging an electric vehicle need a circuit that is at least 125% more than the listed current. I wish I had known this feature was going to be implemented, because I purchased a Grizzl-E EVSE specifically because it allows setting the current limit via DIP switches even though I was getting the included Lucid Mobile Charging Cable. Lucid needs to modify the description of their Mobile Cable to indicate this is no longer an issue.
Email customer care.
So I've got a 60amp breaker and the Charge point charger I have limited charging to 80% of 60 amps which is 48amps. However, my lucid air is not allowing me to choose 48amps charging speed and is restricting me to 32amps. What do I need to do to allow it to draw the full 48amps allowed by my charger and the code?
Thanks!
Set the ChargePoint for 48a, and set the Lucid to 80a. The CP will limit the current to 48a.
HOW to set lucid to 80a is my question. Max it will let me is 32a.
