- Apr 11, 2022
- San Diego
- M4 Cab, X5 50e, Palisade
This is actually incorrect. In the Lucid, the brake pedal does not cause regen. It is simply mechanical. Other EVs, like my I Pace, work as you describe.There are two options in regenerative braking. Choose what is appropriate for you. Also when you press the brake pedal, it first uses regeneration and then uses actual brakes.
