- May 1, 2022
- San Francisco, CA
- Air Touring
- MX1KDTYY
Which version of the OS are you running?I use an Android phone (Samsung S22 Ultra). The call quality in the Lucid is atrocious. Tinny, choppy, bits-and-pieces of the conversation is missing.
I don't know for sure, but I think it is (again) related to the slow, time-lagging UI. Someone in the forum said the Lucid UI funcions are run using VMs. The low-perforamnce, slow response of the VM might be the cause of some of the issues. In a previous post, I said the navigation on the Lucid is worthless because of the lag. I suspect all these issues might be related.
I don't think these issues (UI, laggard performace at various in-car services) are just "SW bugs". that can (will) be fixed with patches I think there is a fundamental archtecture/perforamnce problem with the (computing) platform.
After 2.0.x, you should be experiencing relatively little lag. If you’re on an earlier version than that, you need to contact customer care right away and get them to push several updates to you.
