Music lag
Hbaeuerle
Lucid air
So every time i leave my driveway i turn on Tidal and it plays a song right away. After driving about 1-2 minutes the sound stops and buffering starts which lasts 3 minutes.. any way to increase buffer in settings or is there another way with dealing with this minor issue?
I don’t know if this is the cause of your issue, but do you have WiFi turned on ?
I have found that turning off WiFi helps alleviate this problem.
This happens when you transition from wifi to LTE, particularly if you have bad LTE service. The car takes a minute or two to transition (yes, it’s a little annoying), and thus may stutter while it’s doing that if you have an iffy connection.
