- Mar 13, 2025
- 2025 Air Grand Touring
I don't know. I'm a potential buyer trying to get a handle on this issue.Yes. Is that rare? I did not know
With respect I'd suggest traveling to a Lucid studio, borrowing the car's fob and trying locking and unlocking it yourself. You can turn passive locking and unlocking on and off in the car's settings and see what you think. And/or link your phone as a mobile key and try that.I don't know. I'm a potential buyer trying to get a handle on this issue.
No.Yes. Is that rare? I did not know
1) I don't think the Air has an OBDII port.
True....but there is actually a OBDII to Ethernet converter. And the new FOB will have a couple of years of battery life!1) I don't think the Air has an OBDII port.
2) The fob itself is not the problem.
Your post makes it sound like the problem is with the fob on the Lucid Air. If so, how do you explain the fact that the problem happens when customers use their phone as a key. Same problem.No point in adding fuel to the fire, I think everyone understands and is aware of it.
To prospective buyers, yes Lucid is aware of this, and this has been fixed on the Gravity with a complete overhaul of the key fob. They've heard the complaints on the Air fob and are improving on it for the Gravity. Now, will us Air owners get an updated retrofit key fob to address our issues? Time will tell.
It's not just the fob, it's the access module in the car which both the fob and the mobile key (app) talk to. We can't just get fancy updated Gravity fobs for our Airs, because it's an entirely different technology on the car's side.Your post makes it sound like the problem is with the fob on the Lucid Air. If so, how do you explain the fact that the problem happens when customers use their phone as a key. Same problem.
Lucid should make a very clear statement about what the problem is. We are not adding fuel to the fire when all we want is a "fix" so that we can get into our cars. That's it! That's all. Tell us why it's happening and that you are working on fixing it.
Makes sense. I get it that everything should be focused on getting Gravity out the door by the end of April. But, if new hardware is needed so that Air customers can get into their cars, we expect Lucid to do the right thing and recall cars that have annoying (and probably dangerous) lockouts.It's not just the fob, it's the access module in the car which both the fob and the mobile key (app) talk to. We can't just get fancy updated Gravity fobs for our Airs, because it's an entirely different technology on the car's side.
It's not clear that it is a huge issue, and I don't think anyone would consider it a reasonable application of lemon law. It does not stop you from using the car, it is a minor annoyance. Grating, but minor.any of you file a lemon law suit on this? Clearly it's a huge issue. (been lurking for a while.... contemplating a purchase)
I’m not a lawyer, but I would be very very surprised if any attorney agrees this is a lemon law issue. Even if the fobs don’t work (which they do, perfectly fine, with a fresh battery), the mobile key and key card do.any of you file a lemon law suit on this? Clearly it's a huge issue. (been lurking for a while.... contemplating a purchase)
It's reasonable to expect fairness in marketing. Lucid has a problem with unlocking. I don't know if Lemon Laws would cover such a thing. Why doesn't Lucid simply tell customers about this problem? They lose credibility by staying mum.any of you file a lemon law suit on this? Clearly it's a huge issue. (been lurking for a while.... contemplating a purchase)
Segbrk may think it's minor...maybe because it happens less frequently to them. BUT, if it is a minor problem, why doesn't Lucid tells us what's going on and if a fix is in the works or if we have to live with this for the life of the car?It's not clear that it is a huge issue, and I don't think anyone would consider it a reasonable application of lemon law. It does not stop you from using the car, it is a minor annoyance. Grating, but minor.
Borski: You write that the fobs work. I can tell you that they work some of the time. Maybe yours work all of the time. We finally had the service center look into our unlocking problems. They had the car for a week or so. We got the car back and the fobs work about 2/3 of the time. The service center even gave us a couple of suggestions: put the fob in a faraday cage (didn't help), turn off Wi-Fi (Wi-Fi has been turned off for months). And, because Wi-Fi was turned off, it seems we missed a software update (I'm assuming that was the reason for missing the update). No-joy even after the latest software update.dI’m not a lawyer, but I would be very very surprised if any attorney agrees this is a lemon law issue. Even if the fobs don’t work (which they do, perfectly fine, with a fresh battery), the mobile key and key card do.
Mobile key isn’t a lemon law issue as the fobs work.
Proximity lock/unlock isn’t a lemon law issue as you can just use the button.
A lemon law issue does not include “minor inconveniences”, which proximity lock/unlock failing would be.
Now, if you couldn’t lock or unlock the car with the fob at all, by pushing the button, and Lucid didn’t fix that… sure. To my knowledge, nobody is in that situation. It’s inconvenient, but not broken.
I’m not saying it’s good, I’m just saying that’s why I suspect the answer to your question is a big no.
Just tried this - great idea in theory, but horrible in implementation - can only choose 1 action for the button (Lock or Unlock), has the GSM data delay, and wants to launch the app - where unlock has a Yes/No confirmation dialog. A smart API developer needs to do a WatchForTesla equivalent Lucid app.I set up a shortcut on the Action Button of my iPhone to lock / unlock my car, with the hopes that I could use it like a key fob when the proximity sensing refuses to work. Not sure how well it'll work yet but it's a little easier than having to dig my phone out, open the app, wait for the car to wake up, then clicking unlock.
Huh - I haven't experienced those issues. I initially set up the action button to just be a shortcut for "unlock", but decided that i wanted both lock and unlock depending on number of presses. To that end, I used this (just for single- and double-click. I deleted the triple click part of the script):Just tried this - great idea in theory, but horrible in implementation - can only choose 1 action for the button (Lock or Unlock), has the GSM data delay, and wants to launch the app - where unlock has a Yes/No confirmation dialog. A smart API developer needs to do a WatchForTesla equivalent Lucid app.
No, they do not always work. I have about a 75% success rate in having the car just unlock as I approach. The other times, I'm left standing there for 30 seconds to 3 minutes before it opens. Sometimes in the pouring rain. And I've tried using my iPhone instead of a fob, and that's worse.Even if the fobs don’t work (which they do, perfectly fine, with a fresh battery)
