- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
Is the range over 400 miles?![]()
The model S Plaid has only a slight range reduction. I would put the over under at 450. It will be just under the DE performance.
According to Erich Bach, the range will be over 400 miles. However, it's not clear whether that is with the aero wheel covers which Lucid said add "tens of miles" to the range.
There are several reasons I think the range will be well under the DE range. Although the Sapphire and Dream share the same 118-kWh battery pack (which I assume also means the Sapphire will use the Samsung instead of the LG Chem batteries), the Sapphire battery pack is apparently being tweaked to produce more current. (Remember that the Dream power is limited by the battery pack, as its 1,111 hp is well under the rated power of the two motors.) The car's track is 1" wider in the front and 2" wider in the rear, inevitably adding to aerodynamic drag. Lips and spoilers have been enlarged to increase downforce, which always comes at the expense of drag.
One reason the range in the Model S Plaid is only slightly reduced over the Long Range is that the bodywork is identical between the two versions, with the same wheel and tire options available on both versions. And even when fitted with the same wheels and tires, the Plaid range still drops 27 miles against the standard range (348 miles vs. 375 miles). I suspect the Lucid Sapphire will exact a greater range penalty against the Dream Edition.
My guess is that the Sapphire will see over 400 miles of range only with the aero wheel covers installed.
