Got it, thanksOk, my assumption is that you need a transfer switch, manual or automatic, just like a generator
Yep, that's my understanding as well. The transfer switch isolates the LCHCS from the grid and connects it to your home's critical loads.Ok, my assumption is that you need a transfer switch, manual or automatic, just like a generator.
oThe charger cable provided with the car will work just fine in a 14-50 receptacle and will charge your car up overnight. You should get around 30 miles per hour of charge. The Lucid EVSE will charge your car at ~18Kw providing around 80 miles of charge per hour. The main reason I bought the LCHCS (Lucid EVSE) was for future power outage protection, but the software for that feature is not yet available. Also, the software does not currently allow you to schedule your charging time. If it is plugged in it starts charging.
Of course the software doesn’t currently allow scheduled charging. It will once I buy and install my EVSE lol!The charger cable provided with the car will work just fine in a 14-50 receptacle and will charge your car up overnight. You should get around 30 miles per hour of charge. The Lucid EVSE will charge your car at ~18Kw providing around 80 miles of charge per hour. The main reason I bought the LCHCS (Lucid EVSE) was for future power outage protection, but the software for that feature is not yet available. Also, the software does not currently allow you to schedule your charging time. If it is plugged in it starts charging.
So, here is my question about it not being enabled via software ....The bidirectional capability is not enabled via software. Also, the hardware (transfer switch) is still not approved yet so that's also unavailable for the time being.
Am I supposed to pay an electrician to install a 220V + Lucid EVSE unit + 100Amp panel and then once the transfer switch is approved, pay an electrician to install the transfer switch as well?
Or, am I supposed to just pay an electrician to install a 14-50 in the garage and use the cord. After the transfer switch is approved, then pay the electrician again, to do the 100 Amp panel + transfer switch?
For those of us who want bi-directionality of electricity flow to protect from power outages, what strategy are people using ?
I received my Lucid LCHCS surprisingly fast and earlier than expected last month! Since I have not received my Black/Tahoe AT, I haven't yet had my electrician do the install but hope to get that taken care of soon. At first glance, the installation manual doesn't doesn't even mention bidirectional charging even though that feature is going to be a future capability. The bidirectional capability process and equipment, as discussed in this Forum and in other resources, hasn't been officially released yet as the "official" Lucid path forward for implementing that feature. That being said, conceptually Lucid's approach will be similar to the installation of home generator or solar backup systems in that some type of transfer switch (manual or automated) will be needed to be added to your LCHCS to enable the system to be isolated from your power grid. Several of these transfer switches are available commercially today for home generators. I haven't heard whether Lucid is planning on designing and selling their own transfer switch or just spec out what we would need to get from what is already available.So, here is my question about it not being enabled via software ....
Qmerit is the installer partner but they are just local electricians. They have not specified what kind of transfer switch or other hardware to install for bidirectionality.Correction on my previous statement when I compare it with Ford, Lucid does indeed have a bidirectional installer partner:
Lucid - Qmerit
qmerit.com
I do agree with you about current status of unidirectional charging.Qmerit is the installer partner but they are just local electricians. They have not specified what kind of transfer switch or other hardware to install for bidirectionality.
It's actually a downgrade since you can't schedule a charge on it. I honestly would hold off until they introduce scheduled charging either through the car or the EVSE.I'm getting ready to take delivery of my Lucid and ordered their $1300 home charger to replace my existing Tesla charger. I've now determined that I'm just going to use it with the existing 60A line, instead of rewiring. Is there currently any advantage to using the Lucid CHCS charger on this level of connection (better software integration, app experience, etc.) vs. a 3rd party 48A charger?
The current Tesla Wall Connector can only do 48A, while Lucid can do 80A on a 100A circuit. However, your current wires are rated for a 60A circuit, so there's no advantage either way if you don't change out the wires for 100A circuit.I'm getting ready to take delivery of my Lucid and ordered their $1300 home charger to replace my existing Tesla charger. I've now determined that I'm just going to use it with the existing 60A line, instead of rewiring. Is there currently any advantage to using the Lucid CHCS charger on this level of connection (better software integration, app experience, etc.) vs. a 3rd party 48A charger?
That's exactly what I did, replaced an existing Tesla HPWC Gen 2 on a 60A circuit with Lucid's LHCS. It works fine but neither car nor EVSE currently can do scheduled charging. I imagine this will be remedied by software OTA in the next few months.I'm getting ready to take delivery of my Lucid and ordered their $1300 home charger to replace my existing Tesla charger. I've now determined that I'm just going to use it with the existing 60A line, instead of rewiring. Is there currently any advantage to using the Lucid CHCS charger on this level of connection (better software integration, app experience, etc.) vs. a 3rd party 48A charger?
Yes. If your home wifi subnet is 192.168.1.xxx, a firmware bug in Lucid's home charger prevents it from communicating. In that case you'll need to change your home wifi subnet to 192.168.2.xxx. Lucid's OEM is working on a firmware update to fix.So after installing yesterday the charger is working fine but it is unable to connect to my home wifi network . Tried many times yesterday and today and it would get stuck at the “reloading” step. I have to call the relevant tech tomorrow. Has any one else had this problem?
What do you mean by the reloading step? That might have been the issue I had. if you power cycle, it stays flashing white and never goes solid white?So after installing yesterday the charger is working fine but it is unable to connect to my home wifi network . Tried many times yesterday and today and it would get stuck at the “reloading” step. I have to call the relevant tech tomorrow. Has any one else had this problem?
If the Lucid wall "Charger" ,is a combination of 100A EVSE and 240V 2 phase 100A inverter and a disconnect which disconnects the utility power and switches to its inverter, I will be very interested .This is the situation I’m in. Wallbox is great. Once the Lucid charger comes out I’ll swap it for that.
The 240v inverter, single phase with neutral center tap, is part of the car's Wunderbox functionality.If the Lucid wall "Charger" ,is a combination of 100A EVSE and 240V 2 phase 100A inverter and a disconnect which disconnects the utility power and switches to its inverter, I will be very interested .
