My electrian first assessed the existing panel to determine if it could handle the increase in amp demands the Lucid charger curcuit would make. Once confirmed, he then pulled the 220 35 amp breaker, ran 100 amp wiring in a conduit to the wall I want to install the Lucid charger. He added a terminal box there and then connected a NEMA 14 50 socket to it which would accept the Lucid charging cord the car comes with. He then placed a 50 amp breaker in the panel for this curcuit. When the Lucid charger comes, he will hard wire the Lucid charger into the terminal box, swap out the 50 amp breaker with an 100 amp breaker. He will also need to install a automatic transfer switch to isolate the electrical lines running to the panel from the transmission lines leading to the house. He may have to do some other stuff which I am not aware since I am not an electrian. This may include a soft load regulator which, as I understand, slowly ramps up the amps into the house so as not to trip cuitcuts as various motors turn on since they typically surge to turn on.
