In the Wunderbox tech talk it very clearly states that the box has a 19.2 kw “bi directional” AC to DC converter. The inverter on each motor has no capability to produce AC power except to drive the motor. The Lucid wall charger does not convert any voltages, it simply provides an 80 amp electrical interface to a 240 volt, 100 amp breaker. To make it function as a power supplier to your home there is additional equipment required to isolate your home from the grid, this is common in generator installations. Of course, Lucid has to have the software operable to tell it to supply power instead of recieve power. If it can charge a vehicle it already has the software to supply power using the Wnderbox.
