- May 11, 2022
- Fremont, CA
- Pure AWD Ioniq 5 Sienna
- 6GGPB14C
Ah, did you get an ioniq instead of the fisker? How are you liking it?Charging ioniq 5 with lucid
Are you on 2.1.43?![]()
I have 2.1.42. You have to open charge settings on the pilot panel and select the %soc you want lucid to have after charging the other evAre you on 2.1.43?
I'm still on 2.1.42 and my kit just arrived. I connected it to my Rivian like the directions explain, but there is no notification on the pilot panel to start RengeExchange. The literature says nothing about having to be on a certain software version.
I made sure to disable scheduled charging on both vehicles in case that would be a hang up.
I’m unable to get the charging to start either. Currently on 2.1.43. Tried charging a Tesla model 3 and Rivian R1S but neither worked. Tesla claims charging error no power. And there are red lights on the new Lucid charger but there are blue lights at the lucid charge port. Made sure all connections were tight and secure throughout the chain. Tried an Air logo reset also. No luckAre you on 2.1.43?
Tried multiple times. Even the Rivian failed too. Might be a bad adapter as my luck would have itTry again. First connect the lucid charger to the lucid port. Then if you are trying charge tesla, connect the adapter. Wait for 1 minute. Then plug into tesla. Finally use the pilot panel to set the limit.
Wow 9.4 kw is pretty good. It is doing a 40 amp charge! That is faster than my current Level 2 on a 40 amp circuit which delivers a 32 amp charge.![]()
Try using the mobile charger plugged into an outlet before using the Lucid as a powersource.Tried multiple times. Even the Rivian failed too. Might be a bad adapter as my luck would have it
What did you change?I tried it again with my Rivian and it worked. The Rivian is gaining 21 miles per hour. Pretty cool.
Just to confirm, 2.1.43 is not required.
I see that informational card they included in the package must've not been included with yours...I had the cables in the wrong direction! Looking at the pictures, I thought the Lucid with the RangeXchange power pack side of the cable was a larger SUV and therefore the receiving unit to the host car.
I am not a smart man...
Best of luck to your son! Not fun being in the er as I was reminded of a week ago.Lucid did everything right. They even provided the informational sheet. My son was in the ER all night so I'm going on 2 hours of sleep and wanted to try it out between watching the football games/making dinner, etc. Directions are important.
I decided to call Customer Care and was told some interesting information.
They "confirmed" that you need to be on 2.1.43 for RangeXchange to work. This seems to have debunked from a message response above. The employee also stated that internally they should have everyone on 2.1.43 by December 30th.
